Question about Philips E-Box FTR9965 DTV Receiver
TV SET ON STAND BY?
I hope you can help? I have the above flat screen phillips TV with e-box receiver. When switching my TV on, it initially starts to power up as it normally does, the reciver box light turns green and the then the main TV Light situated on the TV automatically after about 10+ secs defaults back to standby?
Once this happends the LED light on the TV itself constantly flashes red and does not come on?
I have checked all the connections and unplugged and replugged everything back in to no avail! - It's a plama 42inch but there is power going into both the reciever and the screen itself?
I have aimed the remote control at the TV and pressed every button, (Wether that is making it worse - I apologise!!), but I am scratching my head with complete dispair.
Please help - any tips/advice will be greatly appreciated
  • angelazx2 Jun 29, 2008
    i have the same problem of staying on standby had it repaired under warranty and told it was the y justain board is this the same as capaciters
This is to do with the capacitors inside the TV numbers 2662, 2663 and 2664 - If you unscrew the back panel of the tv you will see the capacitors towards the top of the tv, from memory around the middle.
Replace the capacitors (make sure you get the polarity the right way round) and you should find all is ok.
Posted on Jun 19, 2008
  • pecmarku
    pecmarku Nov 01, 2012
    Do you mean to change the polarity the right way round differnet from what is in there or is it somewherelse the fault, such is the circuit TNY268P
Is a freeview box or freesat box required with a new phillips flat screen tv?
No, what a free box does is it can receive certain mostly HD channels and play them on your TV. They are nice and would be a nice addition alongside a new flat screen but no they are not required. All you need to play your cable/satellite is a good ol satellite box and some red white and yellows or antenna cable.
Hope this helped.
Feb 07, 2011 | Philips Televison & Video
I can not get the base off
Follow the below instruction on how to the base off your Toshiba LCD TV;
  1. Turn off your Toshiba TV if it is on.
  2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
  3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
  4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
  5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
  6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
I hope the above helps.
Good luck.
Feb 02, 2011 | Toshiba REGZA 52RV530U LCD TV
Model 6620l-cta I had cable and now I don't is it possible to watch this TV without cable. Is there anyway to switch it to a TV mode?
TV is no longer analog, it is digital, which means NO over the air broadcasting for your TV to receive. The ONLY way to receive a picture on this set is to have some sort of input being broadcast, via Direct TV, Cable, etc. You could always use it as a stand alone DVD monitor if you choose. I hope this helps.
Oct 26, 2009 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Aug 15, 2009 | Philips Televison & Video
Need to remove base from Proscan 32" TV
The stand can be removed by unscrewing six phillips-head screws from the back panel. A plastic insert plate is provided to cover the bottom hole that is left when removing the stand.
thats what i found from this site
http://www.crutchfield.com/p_68332LA30Q/Proscan-32LA30Q.html?tp=161
theres a manual on the left side of the screen just under recommended accessories
doesnt show how to remove it but might be helpfull for your settings
hope it helps
Mar 26, 2009 | Proscan 32LA30Q Television
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
HOOK UP sATELLITE BOX TO vcr AND pHILLIPS FLAT SCREEN tv
hello. the first thing is to find the in to ant.!! on your vcr.!!! that's where you hook up the out to tv.!!! from the satellitebox.!!! then you hook up the out to to tv .!!! from your vcr.!!! to your flat screen tv .!!! to the in from ant.!! on your flat screen.!!! that should do it for u .!!! let me know if this help's u. GOOD LUCK.!!!
Jun 23, 2008 | Televison & Video
I am trying to hook my 40 inch flat screen by samsung to my dell computer. i unplugged the cpu monitor and plugged it to my tv and the tv states that the mode is unsupported. What do i do?
Your computer is set to a resolution supported by your dell monitor but not the flat screen tv.
The easiest way to get it working is to turn the computer off, connect the flat panel to the computer and then turn the computer on.
To change the resolution of the flat-panel or monitor, right-click on the desktop, click on properties and then select the settings tab.
play with the screen resolution and find one that works best by trying each one and clicking apply. If you select a resolution not supported by your flat panel, computer will automatically revert to the previous resolution in 15 secs.
Feb 26, 2008 | Televison & Video
Philips E-Box FTR9965 DTV Receiver Logo
450 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
