Question about Kenmore 73952 Gas Dryer
Replace ignitor hi, would you please tell me how i can replace the ignitor? i opened up the back, it seems the ignitor is hidden inside.... not sure how to get to it. thanks,
You have to remove the front. It is at the bottom left. It is a ceramic glow coil and if bad will usually be broken or have a visible crack. An appliance store or furnace repair place will have it in stock. (It is also used on some furnaces and ovens) Bring the old one with you and the model and serial # of the dryer. You may buy a generic one and cut the plug off your old one if it is different. (Be sure to use ceramic wire nuts, not tape or plastic) The metal holder usually can be pried off too. The generic ones are usually around $15 - 20.
Posted on Jun 29, 2008
I put the brake pedal on wrong, now how do I take it off to correct it?
Hi Ajjr,
We would be unable to advise you how to repair this - you must speak with Graco.
Contact Us Graco
Mar 21, 2014 | Graco Baby Gear
I can not open my "key fob" to replace the battery, does anyone know how to open it?
hey,, There are hidden clips inside you just need to pry it apart... some of them the back cover slides off, but most just pry apart. Look at the back and make sure there are no screws and no hidden screws (like those under rubber stoppers, the stoppers must be removed to expose them).. any way once thats verified, simply insert a flat head (blade) screw driver in between the seems and pry it apart.
Dec 28, 2012 | Cars & Trucks
Bake mode would do nothing. replaced ignitor which looked burnt. still does not light. ignitor does get slightly worm. i checked voltage to ignitor and i got 108 volts.
with a new strong ignitor and proper vac to it the gas valve is sticking and wont open,but to be sure tell me exact model number and the part number of ignitor so i make sure it was correct one(if looks just like old one gas valve seems likely problem)
Aug 10, 2011 | Ovens
Hidden files not showing in m2 2 gb memory stick. please tell me how can i getsudhiruu@yahoo.com
Hi friend, As you have mentioned that you are not able to access the hidden files on the memory stick. I wpuld like you to check if the hidden files are being hidden in the OS settings or not.
In order to check that when you will open the folder of memory stick, go to folder options and in the folder options make sure that the Hidden files options is not checked. If it is checked please uncheck it refresh the windows explorer and the files will be displayed
Dec 08, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
I am trying to find the proper way to remove and replace the ignitor on a maytag mdg5500aww
HI- First make SURE the machine is unplugged. Open the door and on the inside of the door frame you will see 2 screws on each side (2 of them go though the door hinges), remove these screws and pull the front panel forward from the top, it will hinge from the bottom and you can pull up on it to take it off. On the right bottom you will see the valve, ignitor and burner assembly. Locate the ignitor on the Left side of the burner, behind the valve, and use a 5/16 in wrench or socket to loosen the bolt that holds it in place. Unhook the wires and plug in the new one. Be very careful not to hit the ceramic part of the ignitor on anything or it will break, very easily. When you put it back o the bracket make sure it is all the way back and seated correctly. Reverse process. You can actually run the machine without the front panel on to see if the ignitor is working; just make sure the door is closed. Hope this helps, be careful.
http://www.reliableparts.com/models/49863
Sep 24, 2010 | Maytag Dryers
Igniter will heat up (glow), and oven may or may not light for 5 minutes (with igniter glowing). After heating, and stabilizing...once the oven starts to cool, igniter will glow again, and may or may not...
The stove should not take over 3 minutes to light. Even if the ignitor is glowing it is impossible to really tell if it is ok or not. When the ignitor heats up it's resistance drops, this allows for the amp draw to get to 3.2 amps or better and that opens the bi-metal inside the oven valve. The oven circuit consists of a control to regulate temp, a safety valve, a ignitor, and a burner. Any open component and the oven will not fire off. If all the components have continuity and the ignitor is glowing, but no joy, I would replace the ignitor. Usually the ignitor gets dim when it is weak and it takes a long time to light off and you might even have to bump the stove and get it to come on. Replace that ignitor.
Feb 02, 2010 | Ovens
Maytag gas dryer, ignitor comes on, gas valve opens, ignites gas, runs for 30 sec the shuts down. Replaced hi temp fuse & thermostat. What next?
Try the ignitor... As crazy as it may seem the ignitor can be bad even if it works....
This will get your dryer back to normal again.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Accessing the igniter on a Kitchenaid Dryer
Normal 0 Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the ignitor attached to the burner. There is a harness you can unplug to test it. If the dryer is not heating at all, before you remove the front panel, you can remove the cap on the front lower panel and start the dryer. Look inside the holw and see if the ignitor glows at all.
If it glows and then shut down before the flame lights, you will need to change the coils on top the gas valve, not the ignitor.
If the ignitor does not glow at all, you will want to test the thermo fuse before the ignitor.
Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. I know this is a lot of info but these are most common problems.
If I can assist you further, please let me know.
Vic
Jun 02, 2009 | KitchenAid KGYS850LT Gas Dryer
My hotpoint gas stove does not ignite from the inside is this the ignitor? and how do I fix it
Well lets think about it. If you see the ignitor glowing then you have a complete circuit. That means the oven control is sending down juice to the ignitor. The oven safety is alloing for continuity because the ignitor is indeed coming on. So what in the heck could be the problem. All the components SEEM to be working. The answer is simple. The ignitor WILL get WEAK and not put out enough AMPS to open the bi-metal inside that safety valve. The way to know for sure is to clamp on an ammeter to the system and do a simple amp draw check, however, we aint all got a hundred dollar ampmeter to check amp draw with.
Look at the ignitor,is it orange or very bright? If it is a mellow orange the chances are it is weak. Replace it.
Jan 02, 2009 | Hotpoint RGB745 Gas Kitchen Range
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The...
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Dec 13, 2008 | Water Heaters
Kenmore 73952 Gas Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
