Question about Samsung LE40R74BDX 40 in. LCD Television
Don't store tv setting LCD40F86BD
Hello, I have a problem with this lcd. I change tv settings and turn off the tv. When i turn on the tv, the settings are the standard. Don't store my changes.
┬┐Anybody known a soluction?
thanks
sorry by my bad english.
regards
My Samsung LCD TV had this problem too. Check you aren't in "Shop mode" (google Samsung shop mode or check your manual) because Shop mode is designed to drop into manufacturer default settings after a few minutes (in case a customer plays with the settings so the shop doesn't have to reset them). I had to go into analog TV mode then select "plug and play" from the settings menu. This time I made sure I was in "home" mode and so far it's OK (fingers crossed)...
Posted on Jan 09, 2009
Im having the same problem, i have had this television for 16 months now. its not just happening when i turn it off but also when im changing the source
Posted on Oct 10, 2008
How ca I connect my wii nintendo and set top box together in KLV-32T550A
Look for something like this at your favorite electronics store...http://www.bestbuy.com/site/eForCity+-+3+Way+Audio+Video+AV+RCA+Switch+Switcher+Splitter+with+Cable/4655143.p?id=1218501028155&skuId=4655143&st=AV Switch&cp=8&lp=3
Copy all of that into your browser and you'll end up at best buy looking at a A/V Switch that can switch between 3 different devices so you don't have to change the cables...also, look for ones that are remote controlled that have more options...I just included this one as an example...hope this helps you!
Jun 12, 2012 | Sony Klv-32t550a Bravia Multi-system Lcd...
LG 32 inch lcd tv. When you turn it on, the screen (no picture) looks like a shattered window. The set is not hooked up to cable, channels aren't set yet. I just bought the tv for my son.
You need to hook this set up to viewable source to verify if there is a defect.
Then select the source, and check for problems, then.
Is the set used or new?
Brian
Aug 02, 2008 | LG Televison & Video
Hello, i just bought an lcd Tv converter made by manhattan. the model is 176156. the problem is in the video section, don't let me change the standards (NTSC, PAL, PAL-NC, etc) want to know if there
I think you press the wrong button that change the settings of your TV to restore it original settings kindly go to menu and find factory settings then press enter..
hope it helps..
Dec 11, 2011 | Manhattan LCD TV Converter/Tuner (176156)...
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
The TV will, on t's own, will go to the DYNAMIC (Fixed) setting every 30 mins. or so and I have to go to the settings I like. Then it will go back over and over again.
hello,
Dynamic (Fixed) setting every 30 mins. Then it will go back over and over again because of store mode has selected. To remove or set to home mode you can enter initial setup. Follow the instructions from TV set . Or enter TV location from menu than choose home.
Good luck.
Apr 01, 2011 | Sharp LC46SB54U 46 in. LCD TV
Hey there just have simple question: Is it possible to lock setting for the different modes? I have found that a little brighter for movies and games works for me but I think that it keeps switching back...
Hello
Just enter to its picture and sound settings by menu option, and do the picture setting as you interested in.
1 Press MENU on the remote control.
2 Use Up, Down, Forward, Reverse buttons to select [ Setup] > [ Picture].
3 Use Up, Down, Forward, Reverse buttons to select one of the picture settings, and press OK
to enter the setting.
4 Adjust the picture quality.
The following picture settings can be confi gured. Depending on
the format of the picture source, some picture settings are not
available
You must set [Home] in [ Location] Otherwise, the settings you adjusted will not be memorized after you
turn off the unit.
You can set the location of your TV to [Home] or [Retail store].
Choosing [Home] gives you full fl exibility to change predefi ned settings for
picture and sound.
1 Press MENU on the remote control and then use Up, Down, Forward, Reverse buttons to
select [Setup] > [Installation] > [Preferences] > [Location].
2 Select [Home] and then press OK to confi rm your choice.
3 Press MENU to exit.
Mar 23, 2011 | Philips 55PFL7705D 55" LCD TV
Ads and blurbs for the tv features come on at top and left side during regular viewing repeating every few minutes. How do we turn them off?
Hello:
Your TV is set on In-Store Mode. You can change it to Home Mode by following these directions:
  1. Press "MENU" on your remote
  2. Press the Up and Down Arrows to select the "OPTION" menu
  3. Press the ">" key
  4. Press the Up and Down Arrows to select the "Initial Setting" option
  5. Press the "ENTER" key
  6. Press the ">" key to select "HOME"
  7. Press the "ENTER" key
  8. Press the "RETURN" key to exit the menu
Mar 06, 2011 | LG 47LG50 47 in. LCD HDTV
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
The picture setting keeps returning to retail store setting
Go back to the store you bought it from. They sometimes lock them.
Mar 25, 2010 | Philips 32PF5531D 32 in. LCD Television
LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Nov 19, 2008 | LG 42LP1D 42 in. LCD HDTV
Samsung LE40R74BDX 40 in. LCD Television Logo
176 people viewed this question
Henry  Thomas
Henry Thomas
