Question about Radio Shack Pro-95 Handheld Scanner
Scanner problem Greetings!! My Pro-95 quit scanning a few days ago. I have tried re-setting it, re-programming it, pretty much everything. Now all i get is hiss when the squelch is all the way off. Even my weather bands are nothing but squelch. I have tried different antennas as well. Any info you may have will be helpful. Thanks, Jeff in Tennessee
  • ROBERT GONZALEZ Jun 30, 2008
    I have the exact same problem with mine. No scanning and no sound only hissing when sqech is all the way down.
    Bobby
    California
    Bobby2you@aol.com if anyone can help.
    Thanks
  • lenny15 Jul 26, 2008
    Pro-95 screen blank! Only have WX. No response with any buttons.
    lenny15@comcast.net
If your situation is such that the frequencies display, but there is nothing but the hiss, it could be a
loose solder joint or broken lead from the antenna connector to the board. I have had mine break loose several times and had to replace the lead and solder it into the board.
Check it very closely
Ollie
Posted on Oct 23, 2008
  • 90 Answers
A component in the frequency synthesizer circuit bit the dust. This is a common problem but may not be cost effective to repair. Radio Shack scanners are not well made & are susceptible to failure.
Posted on Sep 26, 2008
How do you get rid of the Canon DR-7550C -4630 error "The device could not be locked"?
It's usually a software conflict.
If you have multiple scanning programs, the one of them may have it locked. Especially if you have a scanning program that runs as a service.
Jun 13, 2014 | Canon imageFORMULA DR-7550C - Document...
How do i program the current 2011 nascar seasons in scanner? how do i get rid of default settings?
The PRO-95 is a pretty good trunking scanner, but it's far from ideal for NASCAR monitoring. You can use it for that purpose, and the best way would be to clear all of the programmed information by initializing the scanner. Instructions for this process are on pace 83 of the factory manual, and the best programming instructions are also in the manual. If you don't already have it, you can download and print the manual, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
You can find a comprehensive database of active frequencies in your area, or at the race track, and a lot of other useful scanning information, by visiting:
www.RadioReference.com.
BTW, the best scanners for following the NASCAR action are the Uniden BC72XLT, BC80XLT, and the BC92XLT. All are simple to operate and moderately priced. You can also pick them up used on many web sites, including eBay.
Bill B.
Listening in since the 60's
Feb 28, 2011 | Radio Shack Pro-95 Handheld Scanner
I have programmed my pro164 scanner using win97 software and the pc patch cable. i have frequencies programmed to channels onto bank 0. i also programmed the desired talkgroups onto bank 0. problem is when...
you will have to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the www.starrsoft.com website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ .
but if you have tried doing this.i advise do it again.again run the program by connecting the cable again.if you have not tried it then do it again. if still the same problem.then it might be the problem with the scanner.get it rechecked from radio shack. there are many many users facing this same problem this particular model of radioshack scanner and other model in which this same problem occurs is pro-197. get it checked with radio shack.tech. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 27, 2010 | Radio Shack Pro-97 Handheld Scanner
Scanner will not scan the 800 band
You didn't mention your location or the type(s) of digital system signals you lost, but if you've been listening to an EDACS system it's possible that the manager has switched on the PROVOICE security option. That would prevent your scanners from recognizing the effected users and would also account for both scanners being effected. If your area is using EDACS I suggest that you visit www.RadioReference.com to check on system particulars.
The PRO-95 is also known for losing its logic and requiring a RESET or INITIALIZE, although it would odd for two units to go squirrelly at the same time.
If all else fails, you can RESET or INITIALIZE the scanners to bring them back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
Unit (Pro 95) will not scan trunk tracker stations at all. I have programmed this radio many times previously and it seems that the programming ROMs are misbehaving. The radio works fine in all modes...
go to page 23 of the manual (at "http://support.radioshack.com/manuals/ome20-525.pdf" if you don't have it) it has some cures that you can try there. good luck!
Feb 02, 2009 | Radio Shack Pro-95 Handheld Scanner
Program prblems
your scanner has an attenuater.it lets you program your scanner to reduce scanners sensitivity .check to see if its on or off.
Jan 06, 2009 | Radio Shack Pro-95 Handheld Scanner
The scanner doesn't want to scan?
When you first turn on the pro 95 and the dual trunking screen is still on insert (gently) a pin or straightend paper clip in the small hole just above and to the right of the external power plug. That will reset the radio. Once it is reset (wait until it finishes resetting) you may need to initialize it. Turn it off then back on, while it is still displaying the dual trunking screen press "0" and then the "1". Do not turn the radio off until the Initializing is finished.
Now re program your radio if you with to use the "SCAN" button. Other wise you should be able to use the "search" button to select the service you wish to listen to.
Hope this helps.
Nov 08, 2008 | Radio Shack Pro-95 Handheld Scanner
Battery holder for Pro 95 scanner
Your pro 95 takes the same yellow rechargable battery pack as the pro 97. It is available at the site listing below. It is their #100-006. It cost 5.99 plus 10.95 shipping. I ordered it 4 days ago and got it two days ago. You may be able to save on shipping by calling them and requesting some sort of slower shipping.
https://www.greamerica.com/shop/cgi-bin/cp-app.cgi?usr=51F4658914&rnd=7881653&rrc=N&affl=&cip=71.106.150.99&act=&aff=&pg=prod&ref=100-006&cat=Radio+Scanner+Accessories&catstr=HOME:Radio+Scanner+Accessories
Nov 07, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
122 people viewed this question
Top Radio Shack Radio Communications Experts
Iron
Iron
Robert McClure
John
John
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
