Question about Hoover Vacuums
Carpet vacuum attachment quit working after sucking up a bedskirt. Bedskirt has been removed but carpet attachment will not work. My old vacuum had a reset button on the carpet attachment for use when the carpet attachment sucked up something and turned off. Does the Hoover have such a feature, and, if so, where is it? If not, how do I fix the problem and how do I keep it from recurring? Model # S3765-040. Serial # 100700081298. Purchased 2/08.
I have a Hoover Conquest approx. 4 yrs old. The turbo head is not working Model No. PB4 230-240V AC 50Hz 200w CS4901N (N127) I have been trying to locate another one or another one similiar to fit my machine
Posted on Jun 13, 2008
Precision model EL8802...hard to push, sits too low to carpet
An upright cleaner that is in good condition and working properly is always hard to push on loose laid carpet as it is designed to suck the carpet clear of the floor firmly against the mouth of the brush housing. This is so air is drawn through the carpet to aid dust removal and so the brushbar can make full contact with the carpet.
Jun 03, 2017 | Vacuums
Worked well until purchased new thick carpet,now can't push it.cleaned &changed all filters. cleaned brush. tried removing rubber string gasket. no help .
Barry,
Most vacuum cleaners will not roll well on real thick carpets. There are only a couple of vacuums out there that will work on thick carpet. The Oreck Magnesium models and most of the Miele vacuums will work on thick carpet and some manufacturers of carpet will tell you to use one of those two brands. Hope this helps!
Jul 08, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
The carpet attachment is turning but not sucking.
Check the clips that attach the hose to the front of the Rainbow. If one is broken, then it will leak air and reduce performance.
RainVac
www.rainvac.com
800-523-0510
Apr 22, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My Dyson DC17 gets carpet fibers stuck between the brush bar belt and where the belt attaches to the machine (not the brush bar end of the belt) Then it shreds the carpet fiber and I have to tear it apart...
If you're concerned that the amount of fibre your carpet is shedding seems to be excessive, I'd recommend consulting your carpet manufacturer to determine if this is normal, as the shedding period will vary according to carpet type and usage. They may also be able to offer advice on the best way to vacuum it, as they sometimes suggest vacuuming certain carpet types using suction only.
Kind regards,
Jack
Dyson Online Customer Support
Oct 03, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I sucked up a sock into the carpet attachment of my electrolux 3500 series and the carpet attachment cut off. After the sock was easily removed (it was only wrapped around the brush part) I reattached the...
Did you press the reset button? There will be a reset button either on the back of the unit just below the bulkhead or on the top side of the base.
Locate the reset button and press; this should allow the carpet attachment to resume operation.
If you require an Owner's Manual try downloading the Epic 3500 manual from this site:
http://www.aerusvacuums.com/support/manuals/index.cfm
May 01, 2011 | Electrolux Epic 3500 Vacuum
Instruction manual for hoover swish carpet cleaner
my hoover swish dosent seem to **** up much of the water out of the carpet carpet is still quite wet and bot much water is sucked up for the amount of water that goes in the water dispenser
Nov 26, 2010 | Vacuums
Vacuums Logo
340 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
