Question about Alienware PC Systems Computers & Internet
USB ports are not working, the wireless mouse is not working and also I'm un able to downlod pictures. Please help!
    Sergeant:
  • 281 Answers
Did you reinstall windows lately? Did you in stall the correct drivers.
Posted on Nov 02, 2010
How do i use the staples wireless optical mouse with my chromebook?
Wireless mouse and keyboard are supposed to work on chromebook. It is supposed to work just by inserting USB dongel in port. If won't work, test it on a Windows or Mac computer. Wireless mouse and keyboard are supposed to work on chromebook, see customers report at amazon
Amazon com Customer Reviews Logitech Wireless Mouse M560 for Windows 7 8...
But, if works on Windows, it simply won't work for chromebook. No way!
Mar 10, 2015 | Staples Wireless Optical Mouse, Silver
THE KEYBOARD DOESN'T WORK
Please check the port of keyboard / mouse if its / usb-port then try some other port if other then use connector to DB port sure after transferring keyboard / mouse please restart device or system otherwise install required software for wireless devices
Jan 27, 2014 | GE Wireless Optical Mouse
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
My wireless mouse was working, and then it stopped working all together and the usb reads as unknown device. the batteries are fresh and in full power. how can i fix my mouse without having to buy a new...
Firstly try a different USB port.
If that fails - do the following:
Click on Start, go to RUN and in the command box type:
devmgmt.msc and click on OK
Look for any device with a RED cross or a Yellow Exclamation mark next to it. RIGHT Click on the item and click Uninstall.
Once you have un-installed it, unplug the mouse USB connector and plug it into a new USB port and let windows re-detect it.
Hope that works for you. If it still does not detect it - the USB receiver might be faulty - best is to try it in another PC. If it also fails on another pc - it is the receiver and not the PC itself.
Feb 04, 2011 | Microsoft Wireless Mobile Mouse 3000
My wired mouse on my desk top computer (windows XP) won't move. How do I fix this? I opens the mouse, cleaned it, made sure mouse. keyboard etc. was correctly plugged in, nothing has worked. Please help
It would seem that your mouse is broken. They easiest way to tell if it is your mouse that is broken is to plug that mouse into another computer. If you have another computer you should try plugging your mouse into that one to see if that works. If you don't have another computer ask a friend or family member who does to help you out. It seems most likely that you have a ball mouse using a PS/2 port, the plug pictured in green. Fortunately mice are relatively inexpensive. Even laser mice, which are more accurate, easier to use, and don't jam up with lint and dust build up. If the issue is not your mouse, it may be the port to which your mouse is plugged in. If you are using a PS/2 mouse and your port is no longer working you can get a new mouse that uses a USB port. If your current mouse is using a USB port try changing the port it is plugged into. An example of what a USB port looks like is pictured below. It is the picture of the two ports with the USB logo next to it, a dot with lines going to another dot, a triangle, and a square.mthealey716_1.jpgmthealey716_2.jpg
Dec 13, 2010 | Microsoft Windows XP Home Edition
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
My usb ports wont recognize my plug ins
One of the USB devices might be overloading the ports. If you can use a non-wireless mouse and keyboard first and then plug the hard drive in. Try plugging the drive into another computer. If you don't have one, maybe check with a friend and make sure the drive does not have any problems. While you are at the other computer, try the wireless mouse and keyboard and see if it works ok on it
May 08, 2009 | Computers & Internet
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Wireless mini mouse
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Nov 20, 2007 | Belkin F8E825 USB Mini Wireless Optical...
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
Computers & Internet Logo
59 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Steve Allison
Steve Allison
Argospete
Argospete
ddalecki
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
