Question about Vacuums
Location ff hoover wind tunnel t series vaccum motor reset button
  • bigpay175 Nov 02, 2010
    i tried cleaning filters,and it did not work,and i still can not find a reset button on my hoover wind tunnel vacumm t series
  • Vacuums Master
  • 3,083 Answers
I found an answer to this question on another site, and it suggests how to find a reset switch (if it has one), and discusses other problems that can cause this:
http://www.cookkit.net/i-have-a-hoover-windtunnel-cyclonic-vacuum-anyone-know-where-the-reset-button-is. In the blog they mention a thermal reset switch, and if the other suggestions in the blog don't fix it, contact Hoover- I read in another blog they sometimes replace the unit instead of having it fixed.
Good luck, and hope this helps.
Posted on Nov 02, 2010
  • Vacuums Master
  • 17,970 Answers
Stand behind your vac and the reset should be towards the bottom. Some of these reset buttons are hard to locate. This type of vac shuts off when it is full and keeps you from burning up the motor. Make sure to dump it when it is about half full.
Chances are it could just be the thermal protection...my vacuum shut off and like you I went looking for the reset button...however the filters on the top of cannister and the HEPA filter both needed cleaning and once I did that...it started right up. So just in case anyone comes searching like I did for reset button through the web... check your filters and wait about a half hour and you should be good to go.
Keep us updated.
Reset button on hoover wind tunnel
Hi there! There is no reset button on the cleaner. The vacuum has a thermal protector sensor that will shut the vacuum off when the motor reaches a certain temperature. This is usually caused by a clog or filter that needs to be cleaned or replaced. Be sure to check the hoses for clogs and clean and replace any filters if needed. The vacuum will turn back on when it cools off, this can take up to an hour. Good luck!
Jul 10, 2014 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
WHAT VACCUM BAG TO I GET I HAVE A HOOVER WIND TUNNEL PLUS
Uses a "type Y" Hoover bag. Hope this helps, if so, leave feedback when asked. Thank you, Rene(the Vacuum Doctor)
Nov 09, 2009 | Hoover Vacuums
Where is reset button on Hoover Wind Tunnel vacuum?
Hello my good friend, this cleaner doesn't have a reset button or anything, it resets by itself after cooling down, it takes about 30 minutes to cools down.
Nov 07, 2009 | Hoover Company Wind Tunnel U53019 Upright...
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
Hoover Wind Tunnel does not turn on
that is a pretty good lifespan for a hoover, but its probably the power switch that's bad. Hoover uses a very poor quality switch. It shouldn't cost to much to have it replaced
Jul 05, 2009 | Kenmore 33721 Upright Vacuum
Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Dec 25, 2007 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover Wind Tunnel Problem
motor burnout. replace the motor or get a new vacuum
Dec 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
1,680 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
