Question about Lands Phones
No dialling Tone (Onetel CIRCLE BB TWIN model)
Hi, I've had this phone for 1 year to date and all of a sudden the key displays and there is no dialing tone. Have i locked it or has the ebayer set it go like this after a year LOL. Please advise any solutions you may know of.
SOURCE: ONETEL PHONE
When your handset is in standby, press and hold the left pointing arrow until TONE is displayed.
Posted on Feb 09, 2008
we have a ot150 phone but when some one rings it does not ring straight away.it will start to ring when it allmost time for the answer phone to kick in thanks mr williams
Posted on Apr 13, 2008
SOURCE: Siemens Gigaset C1 telephone
Solution not found, but putting it down to the age of the apparatus.
Thank you for getting in touch.
Posted on Jul 24, 2008
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
SOURCE: philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
Posted on Oct 18, 2008
Why does the phone not call out ? It says the way the number is dialed doesn't work?
Did you read the instructions that came with it? I am wondering if you have to dial 9 to get an outside line if this is a home PBX unit?
The other possibility is that the phone is not set to tone dialling and is set to pulse. When you dial, do you her musical tones or clicks corresponding to the number dialled?
Comment back with Make and Model as a comment to this post.
Nov 24, 2015 | Lands Phones
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
CHANGE THE TIME ON MY PANASONIC 7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Mar 14, 2010 | Panasonic KX-T7453 Corded Phone
TIME CHANGE
Hi!
System Time/Date can be set via admin programming or using feature code 692.
To set using the feature code:
1. Dial [692] on the dial pad. A confirmation tone will sound.
2. Enter date and time as follows: YYMMDDHHMM
When the correct number of digits are entered, a confirmation tone will sound.
3. Press the ON/OFF button (SPEAKER button on IP Phone) to OFF to update the display.
YY = Year (00-99) HH = Hour (00-23)
MM = Month (01-12) MM = Minute (00-59)
DD = Day (01-31)
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Vodavi 30-Button XTS Telephone
Panasonic KXT7453
Press PROGRAM
Press PROGRAM
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
Philips dect 521/525 - 3 year old phone - No dialling tone on one handset
Oct 05, 2008 | Philips DECT 2151 Cordless Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
ONETEL PHONE
Feb 07, 2008 | Lands Phones
Lands Phones Logo
137 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
