Ricoh 2035e wont scan to network
We have a Ricoh 2035e multi function machine, and are wishing to scan documents to a shared folder. The connection to the printer is good, as everyone can print to it from all workstations.
However, when we try to scan to a folder, it cannot find the path. We have tried entering the path manually, and it still wont work. On a whim, we tried scanning to a test server we have here, and when we entered that path it worked fabulously. Suggestions anyone?
3 Suggested Answers
damien729
  • 221 Answers
SOURCE: SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Posted on Jul 03, 2009
  • 62 Answers
SOURCE: Trying to scan pics on HP Officejet 7110. Press
Nothing in or jamming document feeder tray.
Change the setup to scan to a file, rather than email.
Try a different USB port.
Reboot all.
Reinstall printer/scanner drivers and software.
Posted on Nov 17, 2009
How do i setup scanner from my machine to my laptop? please start from step 1 including cable connectios and scan to folder instructions. I am using windows 8.1 pro
Before you even start, your machines "Network Support" firmware needs to be up to date to be able to connect to a Windows 8.1 PC.
Secondly your machine has to be networked. No USB scanning supported on Ricoh Devices. Create a shared folder on your C: drive called "scans". Share so "everyone" can access the folder. On the MP2852 select scanner mode and tap the block with "Prg Dest" on the screen. Select Folder and Browse for your PC. Enter your PC Username and Password when asked. Find your shared "scans" folder, select it and then tap OK on the screen. Next enter your name and save. You should be good to go. Keep in mind anti-virus and firewalls can block it. Also ensure your PC is part of a "Home Group" otherwise you will not find your PC when you browse from the MP2852. If your PC is not in a "Home Group" then you can just create a "Home Group" under your "Network and Sharing Center" and while you are there ensure that "Password Protected Sharing" is switched off under your "Advanced Sharing Settings" also found in your "Network and Sharing Center".
May 28, 2016 | Ricoh Aficio Mp 2852 B&w Copier
Laserjet m1136 mfp
Have you considered installing the scan tools on the other computers? Print sharing is a function of windows; assuming that the printer is not a true network printer. Windows does not have the ability to share scanners. But this is where the software can scan the network and find a HP scanner. Also some scanners can perform a "scan-to" function; but I believe the software need to be installed on the destination computers for this to work as well.
Dec 11, 2013 | Office Equipment & Supplies
Xerox scanning error 027-516:server connection error in smb
This means that your machine cannot connect to the network share to which it is supposed to write the scanned documents.
There may be several causes:
- if it worked before, perhaps the server or computer with shared folder to which the Xerox unit is configured to write files is unavailable/switched off, or the shared folder is not shared anymore or has changed security permissions, preventing the Xerox from writing, or the share name has changed
- if it never worked, perhaps the Xerox needs configuring prior to use (how it should deliver the faxes, via network share or email). Refer to it's manual on how to configure scan delivery.
Jul 24, 2011 | Computers & Internet
WHATS THE NAME OF THE CABLE USED TO CONNECT A AFICIO 161 COPIER TO PC FOR SCANNING
Hello!
This will depend on the connection type you want to make.
If you have a switch you need a straight UTP cable. But if you want to connect the machine directly to the PC you will need a crossover cable.
Do not forget that your machine model uses network scaning (I am talking about scan-to-folder). For that you need to creat a shared folder (in your PC with full permitions) and a user (in the machine) with the correct path.
If you have any doubt reply to me. I will be glad to help you
See you
Jul 18, 2011 | Ricoh Aficio MP 161 Black and White Copier
Ricoh 1232c scan to email SSL issue
no work around for machine. you can scan to a folder on the network, than attach your doc to an email. only way to do it on a ssl.
Mar 24, 2010 | Ricoh Aficio 1232C Color Copier
I can't get my RICOH Aficio MP 3010 to scan to a shared folder on my Vista 64 and I've followed all the steps that the manual gave me.
first have you installed the scan driver? if so hopw are you connected to teh computer if it is by usb this is not going to work as the scan function needs an ip address to go through so you will have to connect via a network cable and then get the ip address of the machine from teh printer config page in user tools
Aug 26, 2009 | Office Equipment & Supplies
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
My company recently leased a MP C3000 multi-function machine. The tech who delivered and set them up, did not leave any software or documentation. I would like to set up scan to folder(network folder). I...
you need to set up your destination folder on the c drive of your pc & set it as a shared folder.
You then need to browse to it from the MFP screen & add it as a destination - remember you will need the correct log in name (same as you use to log in to your p.c) & password (again the same as when you log in).
Good luck - call me if you like. Luke: 0121 521 3444
Apr 03, 2008 | Office Equipment & Supplies
Scanning documents
You need to use the Scan to SMB function.
First create a folder, share it over your network.
Go to the MFP and under the scan to SMB enter the IP and path to the folder, enter the ID and password for the computer.
This will scan to the shared folder.
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Help with scanning on mour Ricoh Aficia 2035.
Since this is a  network printer, you can scan to folder,FTP site or email. alot will depend on your network enviroment. SMB is the simplest. The folder you are scanning to need permission to write to the folder. If you have email you need to enter your smtp server IP address in the user tools and an senders email address. the manuals with the copier will help or download them.
Oct 12, 2007 | Office Equipment & Supplies
457 people viewed this question
jasbo
jasbo
