Question about Fujitsu fi-5650C Path-Through Scanner
Stopping before scan complete
We are feeding paper through and the scanner stops at half a page. The paper is in the scanner, it is not trying to complete the scan, it just stops with the paper halfway in. We have replaced all the rollers and cleaned the scanner. Any suggestions?
  • zone48
    zone48 May 11, 2010
    1. What faults are being generated, if any?
5 Suggested Answers
  • 136 Answers
SOURCE: Incomplete feed
try correcting the page width and make sure one page goes through at a time also you can press the bottom of the paper and it will feed better
Posted on Mar 18, 2008
  • 1894 Answers
SOURCE: Canon 4010C
hmmm i thin u r missing some setting in ur driver.
else reinstall the driver
Posted on Jun 16, 2008
  • 490 Answers
SOURCE: Canon 9080C not scanning 11x17 pages
What scanning software do you use? Try downloading Captureperfect from Select appropriate paper size or Scanners maximum. You can also select 'Actual size'.
S. Mohan. India
Posted on Oct 18, 2009
  • 104 Answers
SOURCE: Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Posted on Jul 27, 2010
Testimonial: "Hello TechSatya, The information you have provided is very helpful. We can now notice staple-pins stuck inside the Sensor panel. Thanks a lot."
Documate error 8
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
9080c fails to scan single page; has trouble scanning a batch.
what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
good luck.
Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
Feeding problem
There are quite a few optical paper sensors in any scanner. If one of them is blocked by a shred of paper, the scanners 'assumes' the paper is available and starts scanning. Try to blow air and clean the scanner. Take care not to damage the sensors. S. Mohan, India
Dec 24, 2008 | Canon DR 2080C Path-Through Scanner
Cannon imageclass d660 auto feed stopping 3/4 way through
There are some small plastic pieces in this feed that can do this. This is an older machine, the whole top feeder can be replaced for $150.00 Its $100.00 dealer cost. And they will want an hours labor.
If that doesnt sound good I would buy a new machine.
Dec 23, 2008 | Office Equipment & Supplies
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Incomplete feed
Mar 18, 2008 | Xerox DocuMate 252 Path-Through Scanner
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Nov 20, 2007 | Canon DR-3080CII Path-Through Flatbed...
Brother MFC 8440D
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Oct 29, 2007 | Brother MFC-8840D All-In-One Laser Printer
Fujitsu fi-5650C Path-Through Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
