Question about Canon ImageRunner 2220I Copier
Canon copiers c3100, ir5000, & ir7200 scanning files issue.
We have three different Canon copiers (c3100, ir5000, & ir7200). These units will scan documents to TIFF and PDF files to the network folders on several of our Windows 2003 servers.
About a month ago, all three starting failing to send TIFF and PDF jobs to ONE of the three Windows 2003 file servers (our main data server to be specific), all three models can send scanned jobs to the other two Windows 2003 servers with no issues, this seems to just be a problem with the main file server. One would guess that server is the problem, but all other network devices can connect to that same server without any trouble and we can move files via command line between servers with no problems across all three servers..
We want the three copiers to be able to send scanned jobs to the file server in questions again, has anyone seen this before and have a fix/solution to my problem?
How can I go in and flush the DNS information on these three copiers and get them communicating with the file server again?
I’ve check the switches, no issues there. I’ve check the servers, no issues there. I even checked to be sure the Windows firewall wasn’t on, and still no luck making things work again.
I contacted a local Cannon support center, and they stated that this ability to scan to TIFF and PDF in a Windows Active Directory 2003 domain should not work, yet it does and has been for a long time until this one server was no long accessible by the copiers for some unknown reason. We had a small hiccup around the time the problem started with our two domain controllers, and that was resolve very quickly before this problem appeared.
Any troubleshooting advice would be nice and appreciated.
Tom.
  • JujitsuTom Jun 24, 2008
    I’m sorry; maybe I wasn’t clear about that.
    My issue is that all three of these copiers scan PDF and TIFF jobs to a server. I have created a Windows AD account with privileges to write these files to the server shares and the account is active and working fine. All three servers are W2k3, and of the three, only one cannot be access by the copiers. The account in question can log onto the network from a work station and then access all the shares in question, so I know the account it good at the AD level.
    All the copies can ping the server, but will not interact with it. Since this one server seems to be elusive to the copiers, but not the network itself and it’s the main file server to start with, not sure what the issue is at this point.
    Your questions have prompted me to create a second admin account to emulate the first and see if that can resolve my issue.
    Thanks for the idea.
How to scan from machine to send a computer directly
Posted on Oct 21, 2009
  • 47 Answers
Ok, so working thru the troubleshooting model you have identified the symptoms fairly well but I dont know if you have adequately identified the area affected. In order for the copiers to create a file on a network server they need user names and passwords to access a network resource and they need sufficient rights to create a file. Have you tried to log into the scan folder on the server using the copiers credentials from a workstation?
The next step, of course is to identify what has changed.If you had a problem with a domain controller is it possible the user accounts for the copiers got deleted/damaged/modified?
Log into the internal web page of the copier by plugging its ip address into the address bar of your favourite web browser and verify that its network settings (dns server, domain name, etc) are correct. I believe you can ping the server from the web page as well, if not it can be done from the tcp/ip setup screen on the copier control panel.
There is no way to manually flush the DNS cache on the copiers except for powercycling the device, just make sure you are turning it off by the main power switch near the back of the machine and not the on-off button on the control panel.
I dunno if this qualifies as a solution or a clarification request but I would start with the user accounts and access permissions.
HTH
Posted on Jun 12, 2008
I can't scan - server connection error
this can be tons of different issues. one is the network was changed and there now has no path to the scan file. two do you scan to email or to folder? three there is corrupt firmware, there may be more issues to choose from...
May 05, 2011 | Konica Minolta Bizhub c203 Copier
Canon IR5000 and the finisher unit
Dirty sensor inside finisher, blow whole thing out with air. Sensors look like small black c-shaped with connector with three to four wires. Dust dirt block when not supposed to be blocked. Shutter open sensor does not turn on when the #2 feed motor has been rotated CCW for 1 second.
Jul 07, 2010 | Canon Office Equipment & Supplies
The scan feature, can it scan docs to my computer for easy emailing?
the Ir5000 i belive can't scan to email.... but i believe the ir5020 does. what you need to make it scan to email is a program like E-Copy Desktop. which can scan from the copier to your computer as a pdf.
Jun 15, 2010 | Canon imageRUNNER 5000 Copier
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
I need to know whether the below canon's can scan and what the range of the DPI is that they can scan at; IRC3100 IR3320i IRC2570 Cheers
iR C3100 600 dpi if equipped with network print/scan kit.
iR3320i 200 dpi, 300 dpi, 400 dpi, 600dpi yes, can scan
iR C2570 600dpi yes, can scan
Nov 06, 2009 | Canon PC-920 Black and White Copier
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
Scan to e-mail using Canon ir5000
cant be done with the ir5000s, only the ir5000i. The 5000s only does whats called "pull scanning", where you put the document on the copier and then go to your computer and use an application to "pull" the scan from the copier to your desktop. You can then attach the image to an email and send it that way.
Jul 18, 2008 | Canon imageRUNNER 5000 Copier
1,105 people viewed this question
old marine
old marine
