Ice maker is fixed. We unpluged the frig for about 10 minutes and it is now working. Someone else was given this as a solution from FixYa and it worked for me. Thanks
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position
then try to reset the ice maker unit and worse comes to worse, replace
it with a new one.
The ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open. Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line. Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position. New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production. Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice. Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil. Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure
OR
The water dispenser will not operate properly
Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.” Refrigerator connected to a water supply and the supply
supply and turn water shutoff valve fully open. Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
Kink in the home water source line? Straighten the water
source line. New installation? Flush and fill the water system. Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed. Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
