Small Sylvania TV/FM radio combo. No sound on 2 local channels. Sound on other local channels OK. Most, if not all cable channels OK. Noticed about 2 weeks ago. Have done nothing to try to fix it. Any suggestions.
Problem :
some channels have no sound.
Solution:
Theres nothing wrong with your TV, is a misconfiguration of your Cable / Satellite box.
Check in the Setup of your Box the language option and select "Channel default"
hope to help you.
Please Rate my solution
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS 1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot) 2)plug ur spker to line out jack(green slot in computer) 3) double click on small spker icon (left side to ur screen near clock) 4) click options menu>Properties>chose audio out option 4m drop box(see image) 5)click rear pink in >ok And all done have fun
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot)2)plug ur spker to line out jack(green slot in computer)3) double click on small spker icon (left side to ur screen near clock)4) click options menu>Properties>chose audio out option 4m drop box(see image) 5)click rear pink in >okAnd all done have fun
if your tv has a headphone jack and your truck has a cassette player, they make an adapter in the shape of a cassette with a wire running out of it and a small jack that will hook into the tv and you should get sound out of your truck stereo. if no cassette player, then they also make an fm transmitter that will hook into the tv and then you tune your fm radio to the frequncy required. radio shack or some place like it usually carries things like this.
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
