Question about Hotpoint RVM1425 Microwave Oven
Removed bulb...tripped breaker... lights won't come on..push button controls says lights on/off but no light.
  • 20 Answers
Very DAGEROUS voltages inside the oven, Have a qualified repair technician look at it.
Posted on Nov 02, 2010
Is there an internal reset button?
The short may have blown an internal fuse.
Jan 20, 2015 | LG LMV1630ST Microwave Oven
Counter lights
Hello!
Please consider troubleshooting the circuit of the oven, some connection in it is shorted causing the breaker tripped off.
Hope this help.
Melnavz
Mar 14, 2008 | Samsung SMH7174BC Microwave Oven
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I replaced the light bulb under the unit on my microwave and went to turn it on and it tripped the circuit breaker and smoked the control panel. The only fuse in the unit is still good. Any thoughts?
< - Please let me know your full model number from the tag on the unit and I can can give you the repair information you need.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 05, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Clock on control panel works, control panel counts down when start is pushed, light inside doesn't work nor fan or light under unit. I replaced fuse but wasn't the problem. Any ideas? I first noticed...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 02, 2010 | Whirlpool MH1150XM Convection/Microwave...
Microwave won't come on after circuit tripped
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations.
But you'll almost certainly need to have the control board repaired.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 23, 2008 | Whirlpool MH1150XMQ Microwave Oven
Stove lights
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 13, 2008 | Microwave Ovens
JVM1190 Surface light and fan will not go on
Jan 11, 2008 | GE JVM1651 Microwave Oven
Model # 80419: turntable and hood lamps inoperable
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Nov 25, 2007 | Kenmore 80412 Microwave Oven
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Sep 18, 2006 | GE JVM1651 Microwave Oven
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
56 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
