Question about NRS iTouchless Stainless Steel Automatic Sensor Soap Dispenser
I have an iTouchless garbage can, and the motor is shot on it. I pulled the motor, but I can't find a replacement anywhere, as it seems to be discontinued. Can anyone recommend an equivalent substitute? The motor is a Mabuchi RF-500TB-18280. Thanks.
What is the default code of itouchless door lock
Refer this inquiry to itouchless for validation and resolution
Jun 28, 2013 | Bio-Matic Fingerprint Door Lock Silver...
My garbage disposal will not start from a dead stop.
The motor start winding has gone bad, or capacitor burned out.
Generally disposals are replaced when motor goes bad.
Mostly because the disposal is sealed unit and cannot be easily disassembled.
If you have local motor-repair guy, who has disposal bearing parts, and can get the disposal apart, then repair might be possible... but the bearing seal would be hard to replace.
Copy following link for replacing garbage disposal with tips from when I did apartment maintenance.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 30, 2012 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Water isn't circulating
Almost always the pump is shot. It is only rubber and needs replacing often. It is this part that you should never run the motor without water available to the unit.
Sep 13, 2012 | Boating
In sink erator model I-81 not working.
Stick the end of a broom stick down in and try to un-jam the blades by spinning them. sounds like there is something stuck in there.
Jan 05, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
ITouchless door lock reset
Where can I find instructions on how to rest the finger print and number pass word for my iTouchless BM001 BioMatic Fingerprint Lock Keyless Entry Handle. I bought it at target but lost my instrutions, please help
May 22, 2011 | Itouchless Bm003l Bio-matic Fingerprint...
ITouchless trash can won't close all the way anymore
When the lid is open notice a metal pin that slides thru the lid to the body of the can. With needle nose pliers, pull out pin to the right and remove lid. Now push the manual open button and quickly turn of power button. Now put the lid back on and slide pin back in. Now turn power button back on and see if this corrected your problem.
Oct 10, 2009 | NRS iTouchless Stainless Steel Automatic...
NRS iTouchless Stainless Steel Automatic Sensor Soap Dispenser Logo
110 people viewed this question
Top NRS Home Experts
john h
Bill Boyd
Mike
Mike
Are you a NRS Home Expert? Answer questions, earn points and help others
