Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Waste tone bottle
Where is the waste toner bottle on the imagerunner 2200
  • Anonymous Sep 29, 2008
    I do not see the cover your talking about?
  • lisa896 May 21, 2009
    I can not locate the waste toner bottle?
  • 38 Answers
Bottom left hand side of the left side of the machine there is a small cover with one screw holding it. All you need to do is loosen the screw, remove the cover, and pull out the waste toner container. Please take note that the screw on this cover does not come out all the way
Posted on Jun 16, 2008
Great help Thank you.
Posted on Sep 09, 2008
Thank You! You just saved me a $100.00 service call for a procedure that took 2 minutes!
Posted on Oct 02, 2008
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
How to replace the waste toner box for ir 3300
If you are facing your machine, the waste toner tank is located to the left rear lower portion. You can see a plastic cover with 2 screws. Remove the screws and cover. Remove and empty the waste toner bottle and be sure to clean the opening of the plastic bottle.
May 26, 2014 | Canon imageRUNNER 2200
ERROR CODE E000019-000
this code is related with waste toner fullwhile removing the wast toner from bottle always clear the neck of the bottle from in side with cloth and restarting the machine after inserting the bottle. dont forget to clear the error in the service mode
Sep 27, 2012 | Canon imageRUNNER 2200
(6981A002AA) for imagerunner 2200, 2800, 3300 Print Server: I have also facing the same problem of Error code ...
So, you need to do next:
Because of statics and plastic bottle, the toner is collected on bottle neck, where is two circles. Even if bottle isnt full but the neck of bottle is dirty the error will occure.
Clean the neck with dry cloath, and then with some antistatic detergent, this will take care of the bottle.
But more permanent solution is to disconnect the waste toner sensor. You will see it above the waste toner bottle.Its a white connector with wires. Pull it out.
But then you need to take a very good care of amount of waste toner in bottle, because if it gets too full it could broke the waste toner gears. So that means that you must every time when you replace the drum, empty the bottle too.
May 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error code 0001900 for ir3300
The error code means the waste toner bottle is full. It may not be full, but once the waste toner bottle neck is dirty and the copier thinks it is full. It's a poor design from Canon. The waste toner is on the left rear side of the copier. It is behind a panel with one screw that holds it in. Remove the cover and remove the waste toner bottle and carefilly empity out the waste toner into a plastic bag. Make sure you clean the neck of the bottle. There are 2 windows on the neck. That is where it gets dirty. Return the bottle back into the copier & return the cover, Then turn the main power switch on the right side and turn it back ON and thats it... Good Luck
May 01, 2010 | Canon imageRUNNER 2200
I cannot find the location of the waste toner bottle.
On iR 2200, the waste toner container is located from left side of copier. To be precise, on left side are door with handle (wich is opend to reach paper in fixing assy or duplex), beneath this door ( left lower section from the door ) is small cover with one screw, when you remove it you will be able to see waste toner container. Its a plastic botlle, remove it clean it and dry it.
Feb 28, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
This error indicates that the waste toner bottle is full
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jun 29, 2009 | Canon imageRUNNER 2200
Canon 2200 error code 000019-0000
This error code means that the waste toner bottle is full. Most likely it is not full, the waste toner bottle neck gets some waste toner on it and it blocks the sensor.... It is a bad design by Canon. The waste toner bottle is on the Left side of the copier, toward the rear of the copier. The cover is held in by one screw, the cover comes off and the Waste Toner Bottle is inside. Turn the copier OFF by the Main Power Switch on the Right side of the copier. Carefully, dump the waste toner out in a plastic bag. Hopefully, without any holes in it. Wipe OFF all the toner OFF the neck of the bottle. You will see what looks like a DOT on each side of the neck.Make sure the inside and out side is clean. Reinstall the bottle and cover and then turn the Main power ON and the Code should be gone. Good Luck....
Mar 29, 2009 | Canon imageRUNNER 2200
IMagerunner 2200 - error E000019-0000
For the people who need clearer information as I did. The toner waste compartment is on the bottom left of the left hand side of the machine. It is to the left of the middle bottom panel which has two small ventholes in it.
Once you open the panel you will see a large plastic bottle which simply pulls out. Empty this and make sure the neck and all areas around the neck are clean. Then place the bottle back in and close up the machine. Done
Oct 18, 2007 | Canon imageRUNNER 2200
Computers & Internet Logo
1,073 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
