Question about Epson Stylus CX7800 All-In-One InkJet Printer
Leaking black ink on printed pages
Black ink leaking on pages and also on tray. Changed the ink still doing it. Also copying pages come out fuzzy.
  • Anonymous Mar 18, 2014
    I can hardly make out the items i print from my computer but I can make perfect copies in the copy mode.
    Scholar:
  • 94 Answers
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Posted on Jun 12, 2008
- I have just changed the black ink and now it wont print so I have changed the black ink again and it still wont print anything black - any ideas
The black ink nozzle in the print head might be blocked. Print a test page with a huge black image. Like: just start word, create a square through "illustrations" and fill it completely with black. Print it once or twice and see if finally the black ink may come out.
Through printer properties (windows control panel) there might be additional cleaning options.
Feb 24, 2015 | Office Equipment & Supplies
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
It leaves a black 1/4
See Craig Gillette's answer from Feb21,2010. That's your problem too.
Jan 04, 2018 | Canon Pixma MP500 All-In-One InkJet...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
After refilling my black cartridge, my lexmark X7170 AIO (on printer copy setting) prints out a blank page even after printing an alignment page showing black bars & blue dashes (no other colors?) I...
Try to print some more pages. The ink will take time to go down as it is not free flowing. This is due to the air beetween the new ink and the old ink, after some printing the air is push out and then you can have a clear print.
Sep 11, 2010 | Lexmark Office Equipment & Supplies
Printer doesn't copy
indicates that the page on the scanner is upside down
the printed side faces down
Oct 26, 2017 | HP Photosmart C4180 All-In-One InkJet...
I changed the ink cartridges printed properly once now no black. printer says ink is full but fuzzy and no black?
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} a. On your computer, open your Kodak AiO Home Center software.
b. Click on the Help (?) button.
c. Click on the Maintenance option.
Click on the Clean Printhead option
3.Print Demo Page.
Press Photo and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not print anything black. What do I
run a nozle check, and clean them, if this doesent work, replace colour ink cartidge with a new one
Aug 30, 2009 | Kodak Office Equipment & Supplies
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Black line on back of page
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Dec 28, 2007 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
525 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
