Question about Pen Drive IVO MP3 Player
When i insert the pendrive then its icon appears in My Computer as a removable storage device but when i double click the icon to open then a message gets displayed stating "Please insert a disk".Plz help me......
  • 613 Answers
Use ccleaner which can be downloaded and is free from filehippo.com. Use the registry scanner and follow directions. You can also restart pc and this might fix it.
Posted on Nov 02, 2010
HPv165w recognized in Device manager...But cant open it in My computer..
Try inserting the pen drive into another computer to see if you can open the data on this pen drive.
If not you may need to format the pen drive.
Nov 24, 2012 | Electronics - Others
My 4 GB V30 Transcend pendrive is not getting detected in any OS (linux and windows 7). In windows its saying that driver software installation failed. And in device manager its coming as unknown device....
try to open in another computer see if it opens there n get ur data first coming to the unknown device issue, firstly insert ur pendrive to usb slot firmly then refresh your comp for about 5 times wait till the drivers are installed open "my computer" n see if the pendrive icon is displayed if its displayed double click n start using . If the above procedure does not work first time do repeat it ur pendrive will work for sure
Sep 20, 2010 | Transcend (589307) Media
I want to know what i need to do next after i have put my sd card into my computer, a green light comes on, and i want to know how to get my pictures to come up on my computer, so i can do any adjustments...
1. When you insert a memory card into your computer, it'll be detected automatically and an "AutoPlay" dialog box will ask you to what to do ?
2. Select "Open folder to view files" option from the list.
3. Now, you can easily view the files in the memory card by double-clicking them.
4. If the "AutoPlay" dialog box doesn't appear, goto Start >> My Computer. Here you can view the memory card as a "Removable Drive" with some name!
5. Double-click the memory card's icon to view the files inside it.
6. After your job is complete, you can remove the memory card by just clicking the USB device icon at the right side of Task Bar (Notification Area)!
7. On click, a single option pop-up will appear with "Safely Remove USB Mass Storage Device" message!
8. Just click on that pop-up. A "Safe To Remove" message box will appear.
9. Click on OK button, and manually remove your memory card!
please rate this advice if it helps...tc! :)
Jan 12, 2010 | Electronics - Others
"insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
Oct 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Nov 20, 2017 | Transcend (589307) Media
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
Pen Drive IVO MP3 Player Logo
29 people viewed this question
Top Pen Drive Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Pen Drive Audio Player and Recorder Expert? Answer questions, earn points and help others
