Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic PT53TW53 My set has three blinks..........after 3+ years of excellent performance, it recently shut down by itself...but after being unplugged, it powers up but then three seconds later shuts itself off and there are three blinks....I live in the US Virgin Islands and professional repair is 95% out of the question..I am very familiar with electronic parts, soldering etc....any help for self-repair will be greatly appreciated....you seem to be the man with the knowledge and patience to do this over the internet thanks, drew@surfvi.com I'm having the same problem. Power light is flashing and the TV turns on for a brief moment after it has been plugged back in. My TV is four years old and I have not had any problem with it.
    Genius:
  • 3,422 Answers
I've found a solution which has been given by Slinteriors who is one of the experts at fixya.
3 blinks on the led means shutdown due to the convergence circuits. Its an easy repair you need to replace both convergence amp ICs thier numbers are STK392-110 I will post a link where you can order replacements and they provide free installation instructions as well as free on line tech support while you do your repair by way of instant messaging. I am one of thier repair techs that does the online support. just go to this link i am posting and purchase two STK392-110 Convergence ICs they ship free anywhere in the world. If you need other items such as solder irons and what not just leave a request by clicking the contact link in the lower left collum as they sell all those items they just dont list them all, and they will respond fast telling you what they have.
http://servicemanuals.vstore.ca/
Goodluck,
Please don't forget to rate or accept the solution
Posted on Jun 12, 2008
    Guru:
  • 1,894 Answers
Did u do a hard reset?
  • 1 more comment
  • dewan nafees ahmed Jun 12, 2008
    Panasonic with same problem. 3 blinks after power on for a
    few seconds, no picture or sound.(found from one of our coexperts)
    Solution: replaced two convergence
    ICs (STK392-XXX) located on the large green printed circuit board. ICs
    are very large and screwed into two large heat sinks and soldered to
    board. Cost is approximately $6 each. Easy to replace if careful. May
    be able to access solder joints on bottom of board by removing screen
    on bottom of cabinet or simply remove 4 screws that anchor plastic
    holder to cabinet and tilt up. I did not disconnect any inter-board
    connections. Remove heat sink screws. Desolder using suction bulb or
    solder ******. Works great. Finish off with solderwick braid if
    necessary to clear holes. 40 watt iron is enough do not apply too much
    heat to damage board lands. Remove IC. Clean heat sink by scraping away
    white heat sync compound. Apply generous amount of heat sync compound
    to new IC and coat evenly. Align and insert new IC holes, resolder with
    thin resin core solder being careful not bridge lands. Refasten to heat
    sink. Clean board and inspect for good joints and no bridging. Refasten
    plastic board holder. Carefully clean projection lenses while back is
    off tv. Power up and it should be fixed. Parts are obtainable on-line.
    Solder tools and board cleaner are available at Radio Shack or on-line
    also. I spent $20 on parts and supplies. This is not hard just a bit
    tedious. You can do it.
    Goodluck,
    don't forget to accept the solution if u go by it.
    thank you sir.
I own a Sony KP-51WS520 that has been down in the basement unused (unplugged) for 2 years. I decided to set up my "man cave" and went to turn on the TV. It started right up but after shutting...
Hi Hank,
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. There is no user replaceable Lamp in KP51WS520 TV.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony Televison & Video
Unit self powers down.
ok! maybe you have lost contact at the PCB you can re solder the PCB thats why the oscillation is not working.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Older medallion 55" 1080...switched itself
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Panasonic PT53TW53
First of all thank you for the compliment. 3 blinks on the led means shutdown due to the convergence circuits. Its an easy repair you need to replace both convergence amp ICs thier numbers are STK392-110 I will post a link where you can order replacements and they provide free installation instructions as well as free on line tech support while you do your repair by way of instant messaging. I am one of thier repair techs that does the online support. just go to this link i am posting and purchase two STK392-110 Convergence ICs they ship free anywhere in the world. If you need other items such as solder irons and what not just leave a request by clicking the contact link in the lower left collum as they sell all those items they just dont list them all, and they will respond fast telling you what they have.
Apr 14, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
