Question about Ricoh Aficio SP C811DN Laser Printer
I have a Ricoh C811DN printer and getting the error message "SC303 - Functional Problem" I downloaded the Ricoh error codes and the description for this code is: Charge Corona Output Error 3, Grid Voltage Error, Charge Cleaner Motor error. Any idea what these codes mean and is this something a enduser can fix? I have shut off the printer twice now and have also opened it up and reseated all the enduser exchangeable parts. did not fix the problem. Could the problem be from a faulty user exchangeable part.
  • 903 Answers
Many times, replacing the PCU can fix this problem. For sc303, yellow is the color in question, so try replacing the yellow PCU. If that doesn't fix the problem, you may need to have your printer's high voltage power supply replaced.
Posted on Mar 22, 2011
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
May 19, 2014 | Ricoh Intermediate Transfer Belt Unit for...
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Apr 29, 2010 | Ricoh Aficio SP C811DN Laser Printer
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Error message
It's the fuser. You can try turning it off, wait 30 seconds, and turn it back on again.
If the problem continues, call a technician in to get the thermistor replaced.
It's a common error.
Aug 04, 2008 | Ricoh Aficio SP C811DN-DL Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio  SP C811DN Laser Printer Logo
335 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
aaron douglas
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
