Question about Dell E193FPp 19" TFT LCD Flat Panel Monitor
I replaced the inverter power board it still only comes on momentarily when completly assembled . however if i have all apart and have components lying loosly about and lamps also out of screen lamps will come on and stay on and are intensly bright why does it not stay o on when assembled ?
    Guru:
  • Dell Master
  • 1,705 Answers
It looks like one of the leads is shorting out when you have the monitor assembled. Check everything is islolated and not touching inside the monitor.
Posted on Nov 02, 2010
How to self troubleshooot backlight that comes on momentarily then shuts off
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 16, 2016 | Televison & Video
LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 16, 2016 | LG Electronics 55LE5400 55LE5400 55 LEDLCD...
LCD TV-Vizio e500-bi backlight intermittent
Jul 14, 2016 | Vizio 50-Inch LED Smart HDTV 1080p Full HD...
Is there a feedback circuit that is shutting down the high voltage power supply?
May 11, 2016 | Samsung LN46C630 TV
Momentarily blank screen then comes back to normal vision and sound
Mar 22, 2016 | Vision Televison & Video
Having same problem where TV standby light comes on and logo appears momentarily then TV does not come on fully (backlight it on slightly).
Hello
You have to troubleshoot from its backlight inverter board itself. That is the first possible cause tho this fault to LCD TVs. If backlight inverter board have shorted inverter transormer [wnding short], the inverter board will take tremendous current from power supply, and this can lead to a momentory logo display and then shut down. The second possiblility is with its main digital board. In both cases, the respective board should be replaced as card basis, as there is no repair to these boards.
Feb 23, 2012 | LG 32LH2000 32 in. HDTV-Ready LCD TV
Turn itself off as soon as you turn it on (37MF33ID/37)
in the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is ON then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
but as you mentioned that the tv turns ON for some seconds then automatically turns off this indicates that the power supply board is not faulty but there is a component on the board that is getting over heated because its got weak so due this overheating of a component the circuit gets short and tv shuts off.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Feb 20, 2010 | Philips 37MF321D 37 in. LCD Television
The screen was black when turned on but could make out what was on the screen when facing the light
You have 1 of 2 issues...
1.) You have a Bad LCD Bulb.. You can get a replacement LCD Bulb and change the LCD Bulb inside the Display which is cheaper and easier than replacing the whole backlight panel.... LCD bulbs cost around $12 Be careful these bulbs are Fragile and if bent when installing- will break...
2.) You have a failing Power Inverter... this is located just under the screen display panel,, it is a circuit board that the screens lcd bulb plugs into and the display cable plugs into... this inverter board converts the DC power in the laptop back to AC power because the screen needs more power to power the lcd bulb...
Your Problem Is One of These 2 Things... Your Best Bet Is To Test The Power Inverter First - Since It Is The Easier Of The 2 To Replace/Repair
Nov 16, 2009 | Cars & Trucks
I have a z20lcd1 tv and it has no picture
2)the main board .
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is not faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is blinking then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
Nov 03, 2009 | Zenith Z19LCD3 TV
Power button flashes red. TV comes on momentarily
this is a inverter board defective. please change-it
Oct 31, 2009 | Panasonic TH37PX60 37 in. Plasma...
Dell E193FPp 19" TFT LCD Flat Panel Monitor Logo
111 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
