Question about Samsung CLP 300 Laser Printer
Paper Feed The printer does not pick up the paper from the paper tray and it gets very hot on the top.
  • 2 more comments
  • grippersdad Jun 16, 2008
    I have a CLP-300 Laser Printer and it wastes a bunch of paper because it wont pick up the paper or jams repeatedly. It's a piece of trash. I called tech support and they suggested I clean the rollers with alcohol swabs and I did that but its still jams. Naturally the warrenty ran out about the time the problem started.
    I can find no fixes for the problem anywhere.
  • engravajon Jun 26, 2008
    eagerly awainting the solution fror this problem
  • catch0386 Jun 30, 2008
    My printer has a mind of its own. Certain times, it picks up the paper. More often than not however, it pretends like there's no paper even in the tray. The paper doesn't jam, the printer just doesn't even pick it up. I don't know what's happening.
  • mickandjopie May 11, 2010
    Sounds simple, but how exactly do you pop the band off?
    Problem Solver:
  • 10 Answers
Had the rngineer in to fix another problem and when he went to do a test print the paper stuck... i fix that he said.
have a look at the back of the printer there is a black rubber band. this is the paper pick up
from the back of the printer you can pop it out
check that the rubber is on the right way- need to be that the when you rub it the rough side is felt when you rub away from the printer
rotate the rubber band a full half turn
replace in the printer
hope this helps
Posted on Jun 27, 2008
I'm having the same problem. so far no answer either.
Posted on Jun 24, 2008
My printer keeps telling me to remove jammed paper, but there is no paper in it!! Help, and thanks!
OK do one thing off the printer then restart it.Reset the printer from printer option botton. then off again. After that when you on the printer then the massage naver come.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have a canon pixma mp780 all in one printer. It keeps saying add paper but the paper tray is full.
Check the feed switch, you can put paper in the bottom tray or the top feeder and you press the feed switch to change from one to the other, when the rollers are dirty and paper doesn't pick up you also get that error.
Jan 14, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
Printer will not pick paper
As a test, please try to print something using paper in the manual feed bin.
If that works, remove the tray, take all the paper out, verify the springs on the tray are working again then reinsert the paper and tray and try again.
Thank you.
Oct 04, 2009 | HP LaserJet 1320 Printer
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
False ricoh 1224c paper jam warning
check tthe clips retaining teh feed rollers havent sliped off if it isnt picking up from tray take the tray at top out and then watch from above to see if the rollers are turning to feed paper.. if the lifts out check the side door guide isnt out of plavce check the end paper guides as well//check when you take the tray out look to see there is any paper stuck at the back where the tray sensors ares can cause a lift motor error aswell
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Paper tray problems
If you take your paper tray out and remove your drum unit, out the machine on its bum, so to speak, and it should sit nicely. If u look at the belly of the machine there should be a little grey roller just at the top, if you get some soapy water on an old rag and give it a wipe. Then if you look at the paper tray there is a grey pad give that a wipe as well and then wipe off all the excess water and try to feed from it again.
Good Luck
May 24, 2008 | Brother HL-2040 Laser Printer
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
Samsung CLP 300 Laser Printer Logo
133 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
