Question about Sharp AQUOS LC-32D43U 32 in. LCD Television
I was told there is a Firmware update for Sharp LC32D43U that may fixHDMI input issues....this is not on the Sharp support website. Any thoughts as to where I can source this update?
3 Suggested Answers
SOURCE: sharp agous .. no power
Needs power supply unit, Part# for Sharp MODEL LC-32D43U, RDENCA198WJQZ or DPS-178AP A Try to purchase from Sharp or check the internet, cost should be under a $100.00
Posted on Nov 10, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a Sharp LC32D43U,
Please unplug tv from wall socket for minute to get it reset, replug back in and turn it On, if tv still does not On then It seems power supply board got bad and need to be replaced.
Required power supply board is available in shopjimmy.com and a handy person can replace it easily.
Hope this will help, let me know if there is additional question.
Thanks.
Posted on May 30, 2011
LC-70LE660U Sharp TV not working. It will power on and display "SHARP" in the middle of the screen but does not respond to any inputs. We have tried to hard reset it but it does not respond.
Hello... There are some Sharp models that a software update will fix this symptom. You should go to Sharps' website and follow the directions for downloading and installing a software update. If this doesn't work, then the Main board has to be replaced. I hope this helps!
Nov 26, 2017 | Sharp Televison & Video
4 SEP'08 HI, I HAVE A SHARP ELECTRONIC ORGANIZER ZQ 2850. IT HAS GRADUALY BEEN GOING WORSE; WHEN PRESSING 'ON' BUTTON; RESPONSE FOR STARTING HAS BEEN MIXED. SOMETIMES OK, SOMETIMES STARTING ONLY AFTER...
Try to update the Firmware of your organizer. If you can connect it directly to your PC, you can start from there. Download the firmware from the manufacturer's website.
Sep 04, 2008 | Sharp Computers & Internet
I have a Sharp Aquos LC-37d43u and when I turn the power on the picture and input show up for a second then the whole screen goes black. Any thoughts?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 23, 2015 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Update firmware to download application(8001)
as i read on samsung bada forum they told that the softweres are not competable to your device... bt didnt tell how to update firmware WTF :(
Dec 31, 2011 | Samsung Wave S8500 Smartphone
Frozen Galaxy Tablet
Update your firmware by using your sd card... place sd card in compurter...Go to galaxy website download firmware to your sd card then follow direction from website how to start the download on your galaxy.Good luck
Dec 17, 2011 | Samsung Tab Tablets & eReaders
Flickering screen (LC-52SB55u) with HDMI cable input from Sharp Aquos Blue Ray. HDMI working well from other inputs
Do a quick google for this on the AVForums site where you'll find numerous threads covering this problem. First, select the HDMI input before turning on the blu ray player. The handshake over HDMI is the problem. I have the same problem with a Technika blu ray which is fine on my other TVs.
If this doesn't solve it then you ned a firmware update which can be downloaded from Sharp's website and installed using a USB pendrive or by PCMCIA card from Sharp if you have an older model with a rocker on off switch and no USB update port on the back of the TV.
Nov 28, 2010 | Sharp LC52SB55U LCD TV
Blue ray won't play Avatar?
There is a firmware update for the BD-HP22. I had the same problem with Avatar but after I installed the firmware update, it loaded and ran smooth. Use the USB flash drive that came with the player or any other usb flash drive to load the firmware update. Check the link below for instructions and update file from Sharp's website.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
May 03, 2010 | Sharp BD-HP22U Player
I have a BD-HP16 Sharp Aquous Pure Mode DVD
I solved this issue by downloading the firmware update and installing it into the Blu-Ray player. Follow the instructions in the manual. It seem to work for me. Go to sharp usa website, download updates.
May 02, 2010 | Sharp AQUOS Blu-ray Disc Player
Sharp bd hp20x will not play the new "x files" blu ray disc movie. The on screen message is that I require an upgrade from the manufacturer to play this blu ray can you help please.
If you contact Sharp via the website, you can order a firmware update cd from them, or download one from the website (CD or usb version) Follow the instructions and within 5 minutes your firmware will be updated.
Worked on mine :)
Dec 05, 2008 | Sharp Televison & Video
Won't play a new blu-ray video
I bought a Sharp BD-HP20S and got Stargate Continuum to play on it, only problem was it wouldn't.
Had bad pixilation, jumping picture and stuttering sound.
Went onto Sharp's website and followed the instructions for downloading and burning a firmware update cd (or usb stick).
Made an update cd, put it in and within 5 minutes the update was over.
Result?
Prefect picture and sound.
Really simple and easy to do.
If you don't want to make a cd yourself Sharp will send one out to you if you contact them.
Nov 28, 2008 | Sharp BDHP20U Blu-Ray Player
Sharp AQUOS LC-32D43U 32 in. LCD Television Logo
289 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
