Question about Alcatel Newbridge MainStreet 3630 Multiplexer (90-0412-51)
I'm attempting to run 512K video via a 512K pipe through my Newbridge 3630, I can see the loop at the distant end but when it is connected to the Cisco router I see nothing. I can see my loop via a C loop on the card and via a loopback plug on the back of the card. Do I have to allow for overhead and will it prevent my routers from talking?
2 Suggested Answers
SOURCE:
SOURCE: Newbridge 3600 circuit signal fault
RBS is either all on or all off
Posted on Nov 02, 2008
I need to know how to bypass a heater all together for a isuzu jackaroo2001 3.5lr
find the two hoses that go to the heater , disconnect from the heater core pipes ( normally in the engine compartment at the firewall) and place a joiner in the hoses and clamp up tight---
heater out of the circuit --
Dec 07, 2016 | Isuzu Cars & Trucks
What does it mean when phone is on desktop loop
Hi Shaundra,
A loop line or loop around is a telephone company test circuit. The circuit has two associated phone numbers. When one side of the loop is called (side A), the caller receives a test tone of approximately 1000 Hz(milliwatt test). When the second number (side B) is called, it produces dead silence, but the party on side A hears the milliwatt test tone drop, and is connected to the person on side B. The purpose of the loop around test is to allow circuit testing to a distant central office without needing a person at the far end. The technician can send a tone down either line and measure the response tone on the second line to determine the path loss parameters.
Sep 17, 2015 | Computers & Internet
Reset newbridge 3630 data node to default
To reset a 3630 you need to go to Maint and restore the database, it will ask you which database to restore just hit esc and it will reset the database
Dec 19, 2013 | Alcatel Newbridge MainStreet 3600...
Cant get fuel lines off fuel pump
hi, are they connected thru pushfit and a jubilee clip to secure it and pipe has gone rigid thru time if this is the case boil kettle and pour boiling water onto pipe where it fits over nipple this should make pipe pliable allowing it to come off, some twisting is requred to break seal pipe has created to the fuel pump, if its fuel injection it has chance to be bolted on via the looped end and these always corrode together causing very stiff breaking of the connection, you can try applying wd-40 etc leave for hour then give some very gentle taps to each side of connection then possibly with someones help secure pump best you can to assist against the pressure your applying when trying to undo nut, pref always use hexagon socket not splined to prevent slipping and rounding of bolt heads, you can confidently apply required forcew to release bolts as these are hardened steel and very difficult to snap. hope this helps, let me know if i missed anything and to let me know results, kind regards
Paul.c
May 06, 2012 | Cars & Trucks
End-to-end loop delay specification of ISDN terminals
Disconnect the coaxial cables from the transmitter and receiver of your equipment. They may be marked "Output" and "Input."Connect the jumper cable from the transmit jack to the receive jack. This completes your near-end loopback--and, if everything works, the equipment should communicate with itself.Connect the two cables that you disconnected from the equipment together with the coaxial splice. The completes the far-end loopback and the distant equipment should be able to communicate with itself.Restore the cables to their original positions after you complete the test.
Feb 07, 2012 | Computers & Internet
I dont have a problem. I just wanna know how Newbridge 3600 series multiplexer help me extend telephone lines to a remote areas like Oil & Gas Pump Stations. I have STM 64 mux used as a backbone. So...
Hi Berido, you can extend telephone lines over the 3600 by using LGE and LGS cards fitted with a ringer PSU in the 3600 at the end point, works well, for more info send me a mail, lenconradie@yahoo.com
Sep 08, 2011 | Alcatel Newbridge MainStreet 3600...
Vivitar home page does no list the vivicam 3630 so that I can download the instalation disc data
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 23, 2011 | Vivitar ViviCam 3630 Digital Camera
CPSS doesn't seem to work
You cant connect CPSS to TS0 IT is reserved tried on TS 30
Jul 21, 2009 | Alcatel Newbridge MainStreet 3600...
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3630 Multiplexer (90-0412-51) Logo
35 people viewed this question
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Sameer Raut
Sameer Raut
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
