Question about ASUS P5N-E SLI Motherboard
Asus_P5N-E_SLI can anyone help ,switch it on all fans come on ,motherboard light on green ,not a sound out of it no beeps at all ,have changed graphics card ,taken memory out ,reset cmos ,nothing seems to be working
    Problem Solver:
  • 12 Answers
Double check memory slots make sure they are paired correctly- try just 1 stick in the a and then b slot
Posted on Dec 01, 2010
5 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
Posted on May 15, 2008
Nic61
  • 1073 Answers
SOURCE: A8N Sli motherboards graphic card and CPU capatibilies
Hi!
Nop, it takes only AMD
The infosite about that MB is still up, you will find it here:
http://uk.asus.com/search.aspx?searchitem=1&searchkey=A8N-SLI
There you will find all the info you want. BTW, its not only the MB's size if the nvidia card fits or not, its the size of the case to.
Good luck
Nic
Posted on Apr 07, 2009
  • 5 Answers
SOURCE: my son hoovedred his pc now asus m2n4-sli wont
may be the frequency of RAM not matched with the motherboard's specifications.
Posted on Jul 12, 2009
warlock61
  • 659 Answers
SOURCE: doesn't recognize graphics card
make sure card is fully seated in slot. try removing and reinstalling card
Posted on Jan 30, 2010
Drivers for p5n-e sli motherboard
You can download the drivers here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the upper left hand corner of the screen, type in the model number of the board (P5N-E SLI) and use the drop down to select a category (probably "All"). Good luck.
Oct 17, 2010 | ASUS P5N-E SLI Motherboard
Can a p5n-e sli handle a single 9800gtx? I
Yes as long as the 9800gtx is PCI Express x16. I am assuming the p5n-e is the Asus MB. Since I couldn't find any other Manufacturer using that MB#
Sep 19, 2009 | ASUS P5N-E SLI Motherboard
Asus P5n32 Sli Premium
There is a couple of things you can do to troubleshoot this.
If there is an on-board VGA (video) port on the back, try that.
Clear the CMOS. On that spec board there should be a coloured plastic jumper next to or near the motherboard battery like this >>>>>
If there is no jumper then remove the power cord from the back and take the motherboard battery out for half an hour then replace and see if you get a post screen.
If it still suffers from the same symptoms then there could be micro fissures between solder points on the motherboard as Intel's tend to run fairly hot.
This means you have to re-float the motherboard and is a last resort repair.
If you need anymore help or advice please post back.
Good luck.
Aug 12, 2009 | ASUS AI Lifestyle P5N32-E SLI...
P5N-SLI
HI stukove2000,
What is the 5200 stand for?
Here is Asus approved CPU list link for the P5N-E SLI MB:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5N-E%20SLI
The Corsair TWIN2X2048-6400 5-5-5-15, should work just fine on the Asus MB.
Here is an expanded approved Qualified Venders List from Asus.
http://www.asus.com/999/download/products/1474/1474_10.pdf
You can also see a smaller QVL list in the manual on page 1-18 & 1-19.
The QVL insures total compatibility with the motherboard.
The NVIDIA GeForce 9600 GT will run just fine on the Asus MB. Just make sure your power supply is no less than 500W. A 600W or 650W is preferred.
http://www.google.com/products/catalog?hl=en&q=600W+power+supply&um=1&ie=UTF-8&cid=1841721063482288764&sa=X&oi=product_catalog_result&resnum=1&ct=result#ps-tech-specs
Here is a write up of the Asus mother board: http://www.techspot.com/review/43-asus-p5n-e-sli/
Asus FAQ's of the P5N-E SLI. Good place to check questions about the board.
http://support.asus.com/faq/faq.aspx?model=P5N-E%20SLI&SLanguage=en-us
Good luck stukove2000!
Any more questions?
Mike
Oct 08, 2008 | ASUS P5N-E SLI Motherboard
Blank Screen, no beeps, New Build
Hi Durmo, your troubles may be the SLI card. If you are using a single 8500GT make sure your SLI card is plugged into the motherboard as a single graphics card. See page 3-9 in your manual. If your 8500GT has dual out puts check both for display. Only one will show you display.
If you have this set correctly & you have tested your monitor on another system (& it is good) yet no display from the system than contact Asus. This board was make in 2007 & is warranted up to 2010. You can do this online or call Asus at 1-812-282-2787 M-F EST. Other countrys click the dropdown menu at Asus home page. http://www.asus.com/products.aspx?l1=3&l2=11&l3=473&model=1474&modelmenu=1
Post if you need more info.
Mike
Aug 19, 2008 | ASUS P5N-E SLI Motherboard
P5ne-sli
Try with only one RAM & isolate the problem
try with different slots
Aug 06, 2008 | ASUS P5N-E SLI Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
Mike
May 15, 2008 | ASUS P5NSLI (0610839134670) Motherboard
ASUS P5N-E SLI Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
