Question about Bosch DKE93xxUC Stainless Steel Kitchen Hood
L have bosch dke 925A 90cm hood l need the part number for ligt covers thank you
Please can someone advise how to get at the switch board for a Bosch cooker hood E-Nr DKE 995 A GB and FD 8009.
many of the switches used are of the push in type and have little clips on the sides that need depressed to extract the switch . without the ability to see exactly what you have make it impossible for us to assist . contact an electrician locally .
Sep 21, 2016 | Bosch Kitchen Ranges
Bosch DKE 997E wall cooker hood doesn't work properly
EN Control buttons separating from control mounting bracket. Affected Countries CA, US Affected Appliances HPCN36NS/01, HPCB36NS/01, HPCN48NS/01, HPCB48NS/01 Fault description / Customers complaint / Diagnostic Codes Diagnostic Codes (DC) The following table contains the diagnostic codes, which most commonly occur in connection with the mentioned fault description. Depending on the actual information from the customer, other diagnostic codes are possible. DC Fault description of the customer 160100X45000 Mechanical damage / Holder Root cause On some Thermador Professional hoods with FD 9407 to 9611, the control buttons may separate from the control mounting bracket due to insufficient adhesive between the control mounting bracket and the inside of the hood canopy. Solution Beginning with FD 9612, wider tape was implemented in production. For units built prior to that time, service kit 12022532 is available. The new repair kit includes the control-mounting bracket with wider tape affixed to it, and four screws. The tape will provide more surface coverage to improve the support of the mounting bracket.
Dec 06, 2017 | Bosch DKE93xxUC Stainless Steel Kitchen...
Hi can u pls send me installation manual for Whirlpool for Ikea 90cm cooker hood HOO D10S with carbon filters. Thank you :)
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 09, 2011 | Whirlpool Microwave Ovens
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
Reverse ligts do not work
the fuse box should be on passenger side behind glove box. if not look for panel on outside right of dash. may even have a box under hood on drivers side covered with black cover.
Mar 19, 2009 | 1993 Oldsmobile Cutlass Supreme
Install the chimney cover
there should be 2 or 3 peices of alum off the hood predrill hole's then rivet or steel screws
Feb 12, 2009 | Bosch DKE 9365 Stainless Steel Kitchen...
Am buying a Bosch cooker hood - does it come with filters?
filters required only if you are venting inside your house (ie recirculating the air), if it is going outside, then you don't need them.
Jul 26, 2008 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Extractor hood
Unfortunately NO, use the template provided. Please ensure there are no cables running through the walls before you drill.
Aug 07, 2007 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Bosch DKE93xxUC Stainless Steel Kitchen Hood Logo
172 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
Marvin
Marvin
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
