Question about GE Kitchen Ranges
I have a GE gas range, Model # JGS905TEK1WW, serial # F1225802Q, which was installed in my new home in Mar/Apr 2006. I store items in the drawer. One of these items, a stove-top griddle, has a curved handle. This handle impacts the front upper edge of the drawer opening when I try to open the drawer. It appears to be impossible to push this handle downward in order to pull the drawer out completely. Please tell me how I can access this space to remove the offending griddle.
  • 2 more comments
  • shamrock72 Jun 12, 2008
    Thanks for your response, but the drawer will open only 1 inch, so no screws are visible or accessible. What other suggestions do you have? Could I move the stove out from the wall and remove the back plate? Or remove the oven bottom?
    The drawer below the oven will pull out only 1 inch, so the contents are not accessible. Is there some way to gain access to the contents of this drawer--like removing the back of the oven or removing the oven bottom? Or dynamite?
    If I pull the range away from the wall, how does the back plate remove? Will I have to disconnect the gas line?
  • shamrock72 Jun 13, 2008
    Thanks so much for your detailed explanation. I have a handyman friend and will call him to see if he is comfortable with this procedure.
  • 426 Answers
If you are handy enough you can pull the oven out and access it from the back side, you should then be able to access the drawer, if you want to try something simpler you can feel around the tracks for a release that will allow you to pull the entire tray out. if nothing else will work try to squeeze the tray to the griddle into a reverse axis, you may also be able to putll the tray upward and out to get a little more room to work with. if there is anything else in the tray that u can get out of the 1 inch slot try to get it out
Posted on Jun 12, 2008
  • Lee N.
    Lee N. Jun 13, 2008
    yes you will want to TURN OFF the gas, and disconnect the line
    so that you can get to the screws easier, it should be rather simple toremove the screws from the back of the oven, the entire area behind the bottom plate should be empty space except the shelf assembly, you may find it easier to turn the stove onto its front making sure to becareful not to scratch it... if you do take the gas line off PLEASE make sure that you take saftey first and use all precautions to make sure that the connections are tight and not leaking when you put the hose back on! we wouldnt want your house to have a leak! just a small hint, its eaiser to flip the stove once the burners have been removed so that they dont break any toes, also please be sure that ur not smoking when you disconnect the gas line as redidual pressure exists
  • Lee N.
    Lee N. Jun 13, 2008
    one more thing you could do is feel around on the front of the drawer to see if there are any screws that are holding the front plate on to the assembly, this perhaps would allow a better look?
    Guru:
  • 1,894 Answers
Just press it from sides.
else look out for some small screws from inside.
  • dewan nafees ahmed Jun 12, 2008
    don't forget to accept the solution if u go by it.
    thank you sir.
Tip
Determining the Age of Your GE Appliance
This advice applies to all appliances manufactured by GE. Determining the manufactured date of most appliances is accomplished by looking at the SERIAL NUMBER. On GE appliances this is determined by the following method:
The manufactured date is determined by the 1st two letters of the serial number
Example: FY456789
1st Letter is the MONTH
A – JAN
D – FEB
F – MAR
G – APR
H – MAY
L – JUN
M – JUL
R – AUG
S – SEP
T – OCT
V – NOV
Z - DEC
2nd Letter is the YEAR
A – 1977, 1989, 2001, 2013
D – 1978, 1990, 2002, 2014
F – 1979, 1991, 2003, 2015
G – 1980, 1992, 2004, 2016
H – 1981, 1993, 2005, 2017
L – 1982, 1994, 2006, 2018
M – 1983, 1995, 2007, 2019
R – 1984, 1996, 2008, 2020
S – 1985, 1997, 2009, 2021
T – 1986, 1998, 2010, 2022
V – 1987, 1999, 2011, 2023
Z – 1988, 2000, 2012, 2024
NOTE: Some Kenmore appliances are manufactured by GE and will have the following prefixes in the MODEL number:
362, 363, 464
on Dec 05, 2009 | Washing Machines
Tip
Determining the Age of Your Maytag Appliance
This advice applies to all appliances manufactured by Maytag. Determining the manufactured date of most appliances is accomplished by looking at the SERIAL NUMBER. On Maytag appliances this is determined by the following method:
The LAST two letters in the serial number identifies the date code.
Example: 123456FY
The 1st Letter is the YEAR.
A – 1978/2002
B – 1966/1990
C – 1979/2003
D – 1967/1991
E – 1980/2004
F – 1968/1992
G – 1981/2005
H – 1969/1993
J – 1982/2006
K – 1970/1994
L – 1983/2007
M – 1971/1995
N – 1984/2008
P – 1972/1996
Q – 1985/2009
R – 1973/1997
S – 1986/2010
T – 1974/1998
U – 1987/2011
V – 1975/1999
X – 1988/2012
Y – 1976/2000
Z – 1977/2001
The 2nd Letter is the MONTH
A – JAN
B – JAN
C – FEB
D – FEB
E – MAR
F – MAR
G – APR
H – APR
J – MAY
K – MAY
L – JUN
M – JUN
N – JUL
P – AUG
Q – JUL
R – SEP
S – AUG
T – OCT
U – SEP
V – NOV
W – OCT
X – DEC
Y – NOV
Z – DEC
NOTE: Some later model Maytag appliances are manufactured by Whirlpool. The serial numbers may be in a different format. Check the MODEL number for any of the following prefixes:
106, 110, 198, 562, 664, 665.
These prefixes indicate the manufacturer as Whirlpool.
How can I tell the manufacture date on my electric spectra range?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. The following link explains how this is determined on GE products:
http://www.fixya.com/support/r3576454-determining_the_age_of_your_ge_appliance
The manufacture date is determined by the first two letters in the serial number. The first letter represents the MONTH of manufacture, while the second letter represents the YEAR.
The serial number and model number should be listed on a nameplate around the oven door opening, or lower drawer opening. Some manufacturers place the nameplate on the back of the control panel.
If you have any questions, please post back and let me know. I hope this helps you.
May 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Where do I find the serial number on my 30" GE range because I need a manual for the oven.
Model and serial numbers are on a tag. If you found the model number, the serial is on the same tag. The tag is usually on the back of the unit or on the side of the door, if the unit has a drawer on the bottom, check there also.
Mar 30, 2010 | GE Spectra JBP78 Electric Kitchen Range
Tip
Example: FY456789
A – JAN
D – FEB
F – MAR
G – APR
H – MAY
L – JUN
M – JUL
R – AUG
S – SEP
T – OCT
V – NOV
Z - DEC
362, 363, 464
on Sep 03, 2009 | GE Profile DPSB619ED Electric Dryer
Tip
Example: 123456FY
A – 1978/2002
B – 1966/1990
C – 1979/2003
D – 1967/1991
E – 1980/2004
F – 1968/1992
G – 1981/2005
H – 1969/1993
J – 1982/2006
K – 1970/1994
L – 1983/2007
M – 1971/1995
N – 1984/2008
P – 1972/1996
Q – 1985/2009
R – 1973/1997
S – 1986/2010
T – 1974/1998
U – 1987/2011
V – 1975/1999
X – 1988/2012
Y – 1976/2000
Z – 1977/2001
A – JAN
B – JAN
C – FEB
D – FEB
E – MAR
F – MAR
G – APR
H – APR
J – MAY
K – MAY
L – JUN
M – JUN
N – JUL
P – AUG
Q – JUL
R – SEP
S – AUG
T – OCT
U – SEP
V – NOV
W – OCT
X – DEC
Y – NOV
Z – DEC
on Sep 03, 2009 | Maytag MMV4205 Microwave Oven
How to install a replacement oven ignitor on a G.E. JGBS20 (serial #)ZT117237P
your model is not complete so i am sending you a breakdown of a JGBS20 gas range. there should be more to the model and you can usually find it on the frame of the stove after opening the oven drawer. anyway, the igniter is #218 in the picture. maybe it will help you somewhat to figure out what needs to come off to change it. hope this helps.250
Oct 24, 2009 | GE JGBS20 Gas Kitchen Range
GE Gas Built-in Oven model JGRP17B Door Replacement
pull out the bottom drawer you will find a plate on the left side pillar of the drawer opening the model # and, serial # is there this is all that is needed to order a new door glass
Apr 21, 2009 | Ovens
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Kitchen Ranges Logo
121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
