Dc jack i have a loose dc jack on my cisnet lap top. how do i find out what mm replacemet jack will fit.
  • dicolonel Jan 27, 2009
    dc jack is loose & does not all ways make connection
    Genius:
  • 2,028 Answers
On Ebay there are a few that just sell ac jacks. If you search for your jack, you can find one of these guys, and they really go into detail about the various jacks. ie.. OEM part numbers.
Posted on Jun 12, 2008
Cnanot get a 3.5 headset jacl to fit
3.5 mm jack is for 3.5 mm jack.
Please check first if it is 3.5 mm. More or less will not fit.
Dec 09, 2013 | Computers & Internet
Hi, the charging connector is broken, can it be replaced easily? If so , how do i get to it? the lap top is a TJ74-RB-050UK. Cheers
the dc jack (charging connector) can usually be bought for about 5 pounds or less from ebay. As far as fitting it goes it depends how confident you are. You will need to disassembel your laptop and remove the broken jack from the motherboard and then solder the new one on.
Jul 15, 2012 | Packard Bell (190169) Power Supply
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
When plugged in the unit starts to smell hot like an electical burn,
Turn it on turn it over and see if the fan is operating. If not power your lap top off and replace the fan. You may have to not use this computer until the fan is replaced it is advisable not to. The smell you have may be dust smell when it gets hot. Clean throughly and make sure that all the dust is out of your computer. Also recommended a lap fan also which goes underneath the laptop to assist with cooling.
Lap tops are very touchy and need to be kept cool at all times otherwise you will be purchasing a new lap top if you do not take care of the cleaning or the cooling or the fan not working or spinning slowly. Check all this out. Critical if you do not understand what I mean take your computer to a local shop for immediate care. I hope this assisted you. John
Feb 01, 2011 | Toshiba Satellite P205D-S7802 Notebook
My lap top dont turn on, only the lightning icon will lit when pluged to the power source, but if I take out the battery the lightning icon truns off
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 16, 2010 | HP Pavilion dv9000z Notebook
My lap top tablet gateway cx 2620 is not working Does it have solution to repair it or I need to change all the display?
Sep 12, 2010 | Computers & Internet
Pluged aspire 4520 in at night. next morning, no lights no power. nothing
if the unit will power one with ac adapter plugged in then you have a bad battery. check to see if you dc jack on the lap top lights up when you plug in the AC. if it does not light up then your dc jack or ac adapter is bad.
Jan 27, 2010 | Acer Aspire 4520-5582 Notebook
I have a gateway 3250GZ laptop, the DC in jack
http://forums.whatthetech.com/DC_Jack_Laptop_t105164.html
double check your power cord! i just went thru 3 days of troubleshooting my Gateway M6318. Thought it was my dc jack.... after tearing down my laptop... finding the jack in tact, soldering in tact. testing my power cord... off and on for 3 days.. it was reading 19v.. which is what it should... but as of today began zero reading on tester. Tomorrow I will buy a new power cord to see if this was the correct problem... wish i would have found the above reference site before all the other troubleshooting i had done... tearing down my lap top, pulling, tugging, twisting my power cord to get a good charge.... etc. hope this helps!
Jul 12, 2009 | Gateway MX3228 Notebook
Remove and install new starter
You need a 1/8 in. ratchet and extension with a 10 mm swivel socket or a 10 mm short wrench. Get the wrench on the bolt with the car jacked up, take a pry bar to the inside of the wrench, pry against the frame and it will break it loose. Once loose, you can get it out with a snap-on 10 mm short wrench.
Jan 07, 2009 | 1996 Mercury Grand Marquis
Dc jack
You need to have the brand, model number ready so I can look it up, but first check with the factory so you don't void the warranty, you might be able to turn in your laptop and get it repaired for a small amount instead of having to take it apart and re-sauder it.
I hope this helps
Apr 02, 2008 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
