Question about Canon Pixma MP480 All-In-One InkJet Printer
My printer is jamming the paper every time I try to print something. It pulls the paper on the left side first and then gets stuck. I have tried resetting the printer and do not see anything inside of it.
  • 2,567 Answers
Make sure that the paper is seated properly in the paper tray. The fact that the printer pulls the left side of the paper first might be an indication that the paper is not seated properly in the tray, or the tray itself dislodged.
Posted on Nov 02, 2010
Every time I try to print something, the paper doesn't pull from the tray straight. It pulls to the left side and crumples the sheet of paper so that it can't feed through the printer.
You do not state the type of printer so it is difficult to give exact instructions, but I know what your problem is. Something is stuck in the paper path on the right hand side, hence the reason is skews to the left because the left side is able to advance and the right is hitting the obstacle. If your printer has a paper drawer, turn off the power, remove all cords and the cartridge. Pull out the paper drawer and then carefully stand the printer on it's back so that you can see where the paper goes as it comes out of the tray. You will likely find your problem right there. If you can repost with an actual model I can give you a much better idea of how to find a paper jam but these instructions should help you.
Mar 26, 2011 | Office Equipment & Supplies
Printer jams
try to clean the printer rollers with acohol it should work
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 23, 2009 | Office Equipment & Supplies
Paper is getting jammed hence not printing
Sounds like somthing is caught in the left hand side try looking in it with a flashlight and see if you can see somthing stuck like a twistie tie/sticky label/ staple / sticky tape.... If its in far try using a ruler or a few pieces of paper stacked together to dislodge it.
May 06, 2009 | Lexmark Z2420 Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper jam
MOST HP PRINTERS HAVE A DOOR ON THE BACK SIDE OF THE PRINTER THAT CAN BE OPENED TO REMOVE A PAPER JAM. HAVE YOU TRIED USING THIS TO CLEAN THE PAPER JAM. THERE MIGHT BE SOMETHING STUCK IN THE PAPER PATH THAT IS CAUSING THE JAMS. CHECK THE WHOLE PAPER PATH FROM THIS REAR ACCESS DOOR. OK?
ARCLIGHT1217
Sep 08, 2008 | HP PSC 1110 All-In-One Thermal Printer
Will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Jun 21, 2008 | HP DeskJet 5550 InkJet Printer
Paper problem
At this point, you my wish to try feeding a slightly thicker piece of paper or light card stock through the printer. If that fails and there is no obvious paper jam then I'm afraid there is nothing else and the printer would need to be serviced or replaced.
Sep 09, 2007 | Epson Stylus CX5200 All-In-One InkJet...
Canon MP160 all in one
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Jun 12, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP480 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
