Question about GE Dishwashers
Motor will not shut off. This is the drain pump motor.
  • 1 more comment
  • ednabrit Nov 03, 2010
    The # is ZBD5900/5700 The dishwasher just started up on its own and not gone through a cycle. The motor for the drain will not shut off.
  • ednabrit Nov 04, 2010
    The diagram did not help. Is there anything else we can do. Last time it cost $85 to have an "expert" come and he unplugged the machine and turned it on and it worked? Any ideas please to save my dishpan hands would be really appreciated
  • ednabrit Nov 08, 2010
    Thanks. We were preparing to follow our advice and shut of the fuse for over 24 hours and when we turned it back on it worked. We are sure that your solution would hae worked bur for now our fingers are crossed.
  • GE Master
  • 43,501 Answers
This is most likely a control board problem... the relay that turns the drain functions on and off is stuck in the on position.
To fix this problem a new control board needs to be ordered and installed.
Installation is not that hard, but usually the inside panel of the door will need to be completely removed to access the control board...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Nov 06, 2010
  • GE Master
  • 17,130 Answers
If your drain pump motor is not shutting off then it is possible that the program controller is faulty. The failure of the drain control circuit- short the driver output can be the reason that the pump is activated continuosly .
Since most of these board are filled with epoxy , it must be seen if the shorted device can be taken out and replaced.
Use a multimeter to trace the line back to the PCB, check the board with the continuity of the line from the pump output to confirm .
Posted on Nov 03, 2010
  • GE Master
  • 3,247 Answers
Please provide the model number of your GE dishwasher. Also additional information like did it complete the wash cycle? was it filling with water ?
Posted on Nov 02, 2010
  • Sam Nov 03, 2010
    It is possible the float switch has triggered or is malfunctioning.
    Look at the diagram for item 266.
My Kenmore dishwasher does not fill with water when switch is turned on. What could be the problem?
First thing to distinguish is which motor are you hearing working is it the wash motor or is it the drain motor. Describing what you have above I would tend to think that it would be the drain motor that you are hearing on the drain pump itself. This happens for a couple reasons in a dishwasher. One your Float switch could be defective. Two you could have a leak condition in the unit and the drain pump is trying to pump out the water due to this issue. Three you could have a clogged drain line or exit port where your drainlines goes into your sink or in the drain line itself. Four would be a clog in the drain pump itself or the impellar of the pump is not turning. How much water do you have on the inside of the machine and is the machine draining if it is draining then I would look at the float switch first in the unit. I will await your reply as to your finds and if you have any further questions message me back
Thank you
Rick
Nov 19, 2011 | Dishwashers
In the middle of washing it shows 0E and shuts off. I open and closed the door it start working and does the same thing and middle of washing again. What is wrong?
Hi, it is a Drain Error OE
Which means it is not fully drained out in spite of 5 min. drain operation
The Drain Hose kinked or blocked. The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled.
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Jun 22, 2011 | LG LDF6810ST Stainless Steel Built-in...
My ge washer shuts off at 19 minutes, but filter is clean
The rug backing may have gone into the pump (the white motor thing) you might take the motor out and flush it out if it is clear and it still won't pump out the pump needs replaced.
Feb 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
Water is not draining completely from the dishwasher. About 1-2 inches remain in the bottom. Seems to drain most of the water during the wash cycle, but a bit remains. Thoughts on how to fix this?
either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Jan 30, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Not filling or draining
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Jan 21, 2010 | Bosch SHU43C05 Stainless Steel Built-in...
My Kenmore Dishwasher will not drain.
Some of the energy star models have a p poor motor with plastic pumps parts. The pump reverses direction to pump out the drain water but get in a bind and the motor shuts down. These units should be recalled.
May 10, 2009 | Dishwashers
Motor burned up & now it shuts off with new motor
There may be a clog in the drain pump that is stopping the motor.
Remove the drain pump from the motor and run the machine in the agition mode.
Did you replace the run capactitor also?
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Nov 29, 2007 | GE Nautilus 24" Built-in Dishwasher
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Dishwashers Logo
62 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
