Question about Parrot Audio Players & Recorders
Good morning... the strange thing has happen this week i made sure as always that i have a full charge on my Parrot, i turned it on it makes the beep noise and the blue lite comes on. my phone ask if i would like to connect. I push yes on my phone (enter) excepting the connection. Now, the parrot is not working there is noise in the parrott at all. my phone will not work either because the parrott is connected. Is there anything i can do to fix this problem and contunie to use my parrot as i have for the last 3 months.
SOURCE: can't connect my nokia 6300 to Parrot Bluetooth Car kit V5.1
Try "1234". That's the code on my parrot kit.
Posted on Mar 24, 2009
SOURCE: My Nokio E52 'sees' the CK3000 Evol parrot, but will not connect.
Switched on the E52 the blue tooth option External SIM Modus to On and kept on trying. And then finally the phone asked for accepting the arrot connection. Entered 1234 and it worked.
Posted on Oct 13, 2009
dancandoit
  • 436 Answers
SOURCE: Parrot Car Kit "no signal" detected problem
No signal is normally a result of the power wires been the wrong way round, disconnect the parrot, check memory and switched live are correct the try the unit again, if it still dont work then it will need new software hard wired into it. Find your nearest Parrot engineer from parrot.com
Posted on Nov 16, 2009
dancandoit
  • 436 Answers
SOURCE: how to reset parrot
press and hold red and green button until it says clear memory.
Dan
Posted on Dec 07, 2009
  • 30 Answers
SOURCE: the parrot comes up with memory full when I
try holding the 2 bottons in for 1 min to reset the kit, if this doesnt work it will have to be replaced
Posted on Jan 17, 2010
Polaris 570 started this morning fine .now it turns over but wont start .gas is full ,battery is full charge .
when you moved make sure you did not hit the kill switch that will not allow a spark .. the other thing you can try is to see if there is a spark. you can pick up a spark tester at any auto store
Feb 28, 2015 | Polaris 2014 Sportsman 570 EFI
2007 Equinox won't start, has no power, but battery charger reads that it has 12.9.
Check battery , load or conductance test . Do you have good connections at the battery ? an at the starter B+ stud . Good grounds , no corrosion !
Feb 05, 2015 | Cars & Trucks
2001 chevy impala wont start just make a click sound started fine last night this morning nothing pls help its not the security thing either had that fix on the recall
Before you trouble shoot a car always charge your battery. It sounds like you have a loose Battery Cable to the Starter to me. This has happen to me that's how I know. To confirm this pull on the positive battery cable while someone else tries to start your car. Did it start? If it did not start then it's between your Battery and your Starter. Let's now check your Battery. Fully charge it again and make sure you have 12.6 Volts if your Battery does not take a charge it has a bad cell and needs changing. If your Battery turns out good then you have to check your starter or Solenoid and if one is bad change them both. Remove it and have an auto store check it to see which one is bad. I hope this helps you out. Let me know how you make out.
Jan 09, 2015 | Cars & Trucks
Where are the red and green buttons on a parrot mk6000 when it is built into the car? i can't pair my phone , parrot says memory full
If you have no red and green buttons, then turn your ignition to 0 so your parrot is visible to Bluetooth devices, but no lights on dash i.e. Not to positions 1, then slowly press + then - on the steering wheel vol controls make sure you press each one and hold for 1/2 a second repeat pressing + and - buttons 5 times, the parrot will the delete all phones and you are good to connect a new phone.
Apr 28, 2012 | Parrot Mk6000 Bluetooth Hands Free Kit
What must i do when i starthe car early in the morning preparing to drive
The first thing you will want to do is warm the car up at least 5 minutes before taking off. The bad habit that people have is turning there vehicles on and driving away that same second. Always let it warm up a couple of minutes, also if you want to check the fluids and make sure there toped off. A fluid check is really a once a week thing, there really is nothing else unless you are having problems with you'r vehicle. Just letting it warm up in the morning is the only real thing you have to do when before you leave in the morning. The last aspect to mention would be just tire pressure. If you have all those things then you should be in good shape.
Hope this Helps!
Jun 07, 2011 | 2000 Toyota Corolla
2006 Ford Truck (Diesel) Just Clicks, Won't Start
had the eact same thing happen on my diesel and it turned out to be the alternator which had fried oine of the batteries.... you could put a charge on them and it would run for a week or ten days and then nothing.. clean the cables charge it up and it would go again... finally it just stop taking the charge and I look deeper and replaced the batteries ran fine for two weeks then dead again... alternator finally finished itself off... problem had been a little intermittent till then.. good luck
Nov 15, 2008 | 2006 Ford F-250 Super Duty
Truly MP3 13X only showing blue backlight
same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Feb 21, 2008 | Truly MP313X 1 GB MP3 Player
Top Parrot Audio Players & Recorders Experts
ray gallant
David Payne
David Payne
yobo007
yobo007
Are you a Parrot Audio Player and Recorder Expert? Answer questions, earn points and help others
