Question about Nespresso Aeroccino Automatic Milk Frother
Aeroccino problem. It starts and stops after seconds and it is needed to restart, but it stops again! Thank you
My aeroccino has stopped heating the milk. It starts and immediately cuts off. The other "propeller" that does not heat milk works just fine.
Depending on where you purchased your machine, I would contact either Nespresso or the store/website to talk to them about replacement. This doesn't sound like an easy at home fix.
Mar 26, 2015 | Nespresso Aeroccino Automatic Milk Frother
Nespresso umachine
are you useing the same type of capsules ?whaqt is the model ?
Aug 13, 2017 | Nespresso U C50 Espresso Machine...
"mixer" in cover does not
Nespresso stated in the past that perhaps moisture (water) had gotten into the bottom of the frother and that might have been the reason it had stopped working.Try turning upside for aeroccino upside down for 24 hr. you do not need to do this to the base
Aeroccino jug being stored on the Base. The base does not have an on/off switch; therefore it is drawing full power at all times when plugged-in. If the Aeroccino jug is stored on a plugged-in base it can short-circuit. Once this has occurred there is no troubleshooting that will alleviate the issue, and replacement is the only option.Don't leave the base plugged-in when not using the unit.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 09, 2011 | Nespresso Aeroccino Automatic Milk Frother
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
Compressor starts for about 2 seconds, stops and then starts again for 1 second then stops again for a few seconds and then starts again for a second. Is it the pressure switch assembly? Thanks,
Yes it is the pressure switch ***.If you have been adjusting it,this maybe the problem,if not,replace it to repair the problem,and thank you,please rate.
Jun 15, 2010 | Coleman 5.5HP 15 Gallon Verticle Portable...
Frother not turning on though there is power to the base
just wanted to comment on the issue with the Aeroccino when it stops working. As has been mentioned, Nespresso stated in the past that perhaps moisture (water) had gotten into the bottom of the frother and that might have been the reason it had stoped working. This was not my problem---I was very diligent in preventing ANY moisture entering the unit. But Nespresso has finally acknowledged the real issue. This is Nespresso's partial reply to my query: "Another possible cause for the Aeroccino to not turn on is the result of the Aeroccino jug being stored on the Base. The base does not have an on/off switch; therefore it is drawing full power at all times when plugged-in. If the Aeroccino jug is stored on a plugged-in base it can short-circuit. Once this has occurred there is no troubleshooting that will alleviate the issue, and replacement is the only option." There you have it. Mine would turn on for a several seconds, and merely warm the milk, instead of frothing it. I guess it took us 9 months to short-circuit it. Luckily ours is still under warranty, so a replacement is being shipped. Good luck to all of you with the same problem...I hope you are still under warranty. For those of you with a working Aeroccino: Don't leave the base plugged-in when not using the unit.
Dec 09, 2008 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Oct 06, 2008 | Nespresso Aeroccino Automatic Milk Frother
On/off problems
Found out if you just leave it for 30 seconds after turning the power on but before activating it works fine.
Dec 16, 2007 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
490 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
