Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
I have a model Kenmore Model 911.93402990 bought this used. Oven would not turn off after I bake cookies. Up plug it and plug it back in. Now only just warms up some, not above 140 degrees. It is just warm. Grandmother Stover
Sea Breeze
  • 4655 Answers
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Posted on Mar 27, 2009
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
BIKER T
  • 909 Answers
SOURCE: Oven will not turn off on older Kenmore range
Your oven thermostat has gone faulty. You need to unplug power from the wall. Remove panel that allows access to oven thermostat, Remove knob and see what type of retaining method it has to secure it to the oven. (Does it have a nut or does it have 2 screws holding itself in position.?). How thick is the dial shaft?(5 or6 or 7 mm.thick). With that information, look now at the body of the thermostat. It should have a number sequence in the form of a sticker on it. Write it down. Phone the spares suppliers and quote them the stove model number with the other relevant items you wrote down to ensure the correct thermostat. Note, never remove wires until you are ready to transfer them one at a time from one thermostat to the other until transfer is complete. Reassemble completely and check.
Posted on Oct 01, 2009
Testimonial: "Thanks so much. You have solved the problem and I have the solution within a couple of hours of posting. Amazing!"
SOURCE: My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
Posted on Jun 08, 2010
SOURCE: My Kenmore Warm and Ready drawer self cleaning
My Kenmore "warm and ready drawer" oven has completely shut down with no apparent power. Is there a reset anywhere? Can it just simply 'burn out"?
Posted on Jul 29, 2010
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I recently bought a home with a Kenmore Self Cleaning Ultra Bake Oven but no manual to be found. Serial # 9755994 Model 880 655 124PO. I would appreciate any information regarding this stove and how to...
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Hi we have a Kenmore oven we were baking some cookies in the oven when they caught on fire and the oven through out a code
Unplug the oven for a few minutes and plug it back in and see if the code has cleared,
Jun 18, 2010 | Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Oct 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Burners light ok, oven will not light
Stop time knob needs to be out; you set it for timed bake. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
51 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
