Question about HP ProCurve 2626 (J4900B) 24x10/100 Mbps Networking Switch
Need to accses a switch that has been configured with two factor security. The switch is currently connected via serial to my pc. how can I clear all the config so as to configure same switch for an other site.
    Sergeant:
  • 378 Answers
When prompted for the password, press the clear button and hit enter. This will let you into the switch.
Next to clear the config, type "erase startup-config" at the # prompt, then follow the prompt to reboot the switch.
Posted on Apr 25, 2011
Bought car at auction- no keys. Had key made at GM dealer. Programmed key- key works. Car wont start- Codes are P0633 and P1629. cannot clear codes
DTC P0633 : Theft Deterrent Key Not Programmed
When learning the pre-release password, as well as the challenge and response sequence, the engine control module (ECM) is placed in learn mode. DTC P0633 will set automatically as an indicator that the system is in learn mode and not as a fault indicator. Once the password and challenge/response are learned, learn mode will be exited when the engine is successfully started. At this point, the DTC will be cleared. If the ECM does not exit learn mode, P0633 will remain current and indicate a fault.
The "key" referenced in the DTC descriptor does not refer to the vehicle key. In this case, "key" is referring to the challenge response.
DTC P0633 requires a successful engine start to exit the learn procedure and clear the DTC. If an unrelated malfunction exists that causes engine starting to be disabled or otherwise unavailable, learn mode will not exit and DTC P0633 will remain current. In this situation, the cause of the inoperative engine starting must be corrected before diagnosing DTC P0633.
DTC P1629: Theft Deterrent Fuel Enable Signal Not Received
The theft deterrent module (TDM) sends the pre-release password to the engine control module (ECM) via the serial data circuit. The ECM then sends a challenge to the TDM. Both the ECM and TDM perform a calculation on this challenge. If the calculated response from the TDM equals the calculation performed by the ECM, the ECM will allow vehicle starting.
DTC P1629 is an indicator that the challenge response was not received within the required 2 second window. This does not necessarily indicate a fault is present with the TDM or ECM. Factors such as a long engine crank, a delay in the serial data communication, or B-codes set in the TDM will cause DTC P1629 to set. This DTC should not be used as a fault indicator, but rather as a symptom to assist in the diagnosis of these other systems.
Who checked the codes , you -dealer ? You need to have BCM checked for codes B - codes ! you need a up scale diagnostic scan tool for that , dealer Tech -2 !
DTC B3935 57 : Transponder Authentication Error
DTC B3976 46 : Unconfigured Transponder/Vehicle Configuration Not Programmed
DTC B3060 : Unprogrammed Transponder Identification Code Received
DTC B3055: No Transponder Modulation or No Transponder
DTC B3031: Security System Controller In Learn Mode
Aug 07, 2015 | 2006 Buick Lucerne
How to upload ready configuration file into the new switch?
yes you can upload configuration file on S5300 switch flash using serial connection. Please check below link. is an upgrade guide for deploying a system software. it shows you how to upload system software to the flash, the process is the same for configuration file.
it is possible to connect a laptop to the switch? Ethernet cable, configure ip addresses, enable ftp, configure ftp user and then upload to file to the switch via ethernet?
Apr 10, 2015 | Huawei Computers & Internet
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
I cannot connect to my home wireless network provided by my new ISP, after I ended my subscription to my old ISP. Connection via old ISP was via Dial Up; connection via new ISP is via broadband. I have a...
First of all you may try to check the adapter settings on your computer.
Start>control panel>network and sharing center>adapter settings>check status of broadband(should be connected)
If not right click on broadband connetio and click on connect if still showing as disconnected
You may also check internet option settings.
open IE>tools]nternet options?>connection tab>tick on never dial a connection.
Click on LAN settings tick on automatically detect settings>ok
You may also check for the if the driver for your wireless broadand is working by checking it on device manager.
Try to check if broadband is working on the other computer.
Apr 15, 2011 | Dell Inspiron 630M Notebook
How can I know my router's security password?
Not quite clear as to your problem. Are you trying to access the web-based configuration page for the router (for which you need an administrator password)? Or are you trying to make a wireless connection to the Internet via the router (for which you need the wireless security key)?
Those are two separate passwords, and you may be able to retrieve them both. The administrator password would be stored in the computer that was used to configure the router. The security key should be in the computer which configured the router, as well as any computer which made a wireless connection to the router.
If the passwords are stored, you should be able to retrieve them by installing some additional software.
For the computer that configured the router, download and install this program:
RouterPassView by NirSoft
http://www.nirsoft.net/utils/router_password_recovery.html
For a laptop that connected to the router, download and install this program:
WirelessKeyView by NirSoft
http://www.nirsoft.net/utils/wireless_key.html
Feb 21, 2011 | Linksys (WRT54GC) Router
How can i communicate from my pc to the ups on the 9 pin serial connection
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
higher).
Connect the card to the PC using the cable supplied.
Set up the terminal with the following communication parameters:
9600 bauds. 8 data bits.
1 stop bit. no parity.
no flow control.
ASCII: "echo typed characters locally" option disabled.
Press the Carriage return key. The configuration menu is displayed.
Enter the password (MGEUPS by default).
The main menu is displayed.
Select one of the items in the configuration menu.
Via the serial link or Telnet
Select the "Agent configuration" command by entering 1.
Select the item numbers and modify all the IP parameters (address, mask, gateway).
Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
Select the "Restart agent" command by entering 6.
Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
Select the "Reset configuration to default" command by entering 5.
Nov 05, 2010 | MGE UPS Galaxy 3000 UPS System
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
Sep 19, 2010 | Linksys Wireless-G WRT54G Router
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
I need to know how to configure link proof radware
Hi Nalinfrancis,
One way you can config the LP is to log on to the serial interface and then configure an IP address to the first eth port that is available. Then connect directly to the port using a crossover cable depending on the laptop or pc that you use if it can switch put your laptop/pc on the same network that you configured on the port. Then connect via your browser to the IP address assigned to the LP. Logging with you default username and password. From there you can do all the configuration via the web interface.
Regards,
Andrevz
Jan 03, 2009 | Radware LinkProof Application (904627-cl3)...
Faulty DFL-700 image - missing FWCore.cfg
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
Download Link:
http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
May 05, 2008 | D-Link NetDefend DFL-700 Firewall
HP ProCurve 2626 (J4900B) 24x10/100 Mbps Networking Switch Logo
157 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
