Question about HP Compaq 6510b Notebook PC
HP PAVILLION NOTEBOOK
WANT TO MOVE MY TASKBAR STUFF FROM TOP OF COMPUTER SCREEN TO THE BOTTOM
  • 611 Answers
Right cilk on it to task bar and clik move.
second to do press the task bar drag out top bottom you get it
Posted on Jun 13, 2008
To adjust rotating display of laptop ,taskbar with all icons moves on different(bottom to top)
Step 1:
Has your Windows taskbar suddenly moved to the side of your desktop screen or even to the top? This can be very disruptive to your daily computing, which may mean a loss of productivity at work. Your taskbar could have moved because of a glitch in programming or an inadvertent mouse click while you were focused on something else. The latter is more common and is usually the result of an unlocked taskbar.
Older Windows Operating Systems Windows 98, Windows ME, Windows XP and Windows Vista all utilize similar solutions for this problem. For the quickest route to returning the taskbar to the bottom of the screen, first place your mouse pointer over empty space on your taskbar (space not occupied by an icon or a button indicating an open program) and right-click. Look near the bottom of the menu that appears for the "Lock the Taskbar" listing, and make sure there is no check mark next to the listing. If there is a check mark, it means the taskbar is locked and cannot be moved, so click on the listing to deselect (and unlock) it. With your mouse pointer again over an empty space on the taskbar, click and hold the left mouse button and then move the mouse pointer to the bottom of the screen. When you release the left mouse button, your taskbar should have moved. As long as the taskbar is unlocked, you can also vary its height. Hold the mouse pointer over the upper edge of the taskbar until it becomes a double arrow (pointing up and down). Then click and hold while you drag the upper edge of the taskbar to the you desire. Once you have the taskbar where you want it, remember to lock it again by selecting the listing on the right-click taskbar menu.
Another option is to visit the Microsoft Windows website and download and run an automatic "Fix it" program, which should take care of programming issues. Windows 7
There are three options for moving the taskbar in the Windows 7 operating system. The first option involves right-clicking on an empty space in the taskbar and then navigating to the "Properties" menu (look near the center of the menu) to set the location of your taskbar on your screen. This menu also allows you to change or establish a number of other default settings relating to your Start menu and taskbar. The second option is exactly the same as the first process given for the Windows operating systems previously mentioned. And again, to prevent the format you have established from changing, lock the taskbar by right-clicking on an empty space of the taskbar and selecting "Lock the Taskbar" from the menu. The third option is a bit more involved and requires downloading registry files (files ending in ".reg"), saving them to your desktop and then double-clicking on them to merge them with your operating system. The files can be deleted after use.
Microsoft online support
http://support.microsoft.com/kb/253679
Feb 17, 2013 | Dell Inspiron Mini 10 Notebook
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
O be at bottom
do you mean the taskbar?
if so then right-click on the bar at the side of your screen and uncheck 'lock the taskbar'
then left click on the bar and drag it to the bottom on the screen and it should snap back to the bottom
Mar 30, 2012 | Computers & Internet
Lost start button and icons on my toshiba lap top
Do you mean the taskbar along the bottom of the screen?
If you move your cursor to the bottom of the screen the taskbar should appear. Right click anywhere on the taskbar and click properties. In the properties window, on the taskbar tab, uncheck 'auto hide taskbar'.
Mar 29, 2012 | Toshiba Satellite L655S5158 156Inch Laptop
The start button is found in the upper part of the screen
Your taskbar may have been unlocked and moved to the top of your desktop. I'll continue under that assumption.
  1. Right-click on your taskbar. If checked, un-check 'Lock the Taskbar'. Otherwise, skip to Step 3.
  2. Left-click on your taskbar and drag it to the bottom of your desktop. This is the original position of the taskbar.
  3. Right-click on your taskbar. Check 'Lock the Taskbar'. (OPTIONAL)
Jun 09, 2011 | ASUS LCD Monitor
Start Icon Task bar is on top left of my screen How do I move it to the bottom of the screen?
Right click on the taskbar and select properties. On the taskbar tab on the right hand side you should see a drop down menu which will say top, click on that and select bottom. Then click apply and then OK.
Regards.
Dec 13, 2010 | HP Pavilion dv6000z Notebook
On my Vista desktop, the start/taskbar shows up on the right side when it used to be along the bottom of the screen. why did it move and how can i get it back to the bottom?
First, right-click the taskbar. If "Lock the Taskbar" has a check mark next to it, the taskbar is locked. You can unlock it by clicking "Lock the Taskbar" again. Then, click an empty space on the taskbar, hold and drag the taskbar to one of the four edges of the desktop. When the taskbar is where you want it, release the mouse button.
Mar 08, 2010 | HP Pavilion dv9000z Notebook
My taskbar is not showing after u start the computer
When you say "after u start the computer" you mean before you log in? The taskbar never shows up until you're logged in, so that's the way it's supposed to work.
If you've logged in and you still can't see the taskbar, it's possible that you've configured the taskbar to "auto-hide." To see if that's what's happening, move the mouse all the way to the bottom of the screen, and the taskbar should pop into view. Unless you've moved the taskbar to the top or side - check by moving the mouse all the way to each edge of the screen until you see the taskbar.
Once you see the taskbar, you can right-click either on the "Start" button or on the clock at the opposite end of the taskbar, and select "Properties" from the menu to turn off auto-hide (if you want to - some people like it once they're used to it). If you want to turn it off, pick the "Taskbar" tab on the Properties dialog, and uncheck the "auto-hide the taskbar" checkbox. Then click OK, and the taskbar should stay visible.
Hope this helps.
Oct 06, 2009 | Microsoft Windows XP Home Edition
The start menu and task bar appear to be off the screen on my desktop and auto die mode is not on:(
Check to see if AUTO HIDE is not enabled in taskbar settings, move your mouse cursor to the bottom of the screen if enabled the Startmenu and taskbar will re-appear, if not then it was possibly resized accidently, move your cursor to the bottom again if it turns into two arrows pointing up and down then click and hold and drag up and it should be revealed again.
Aug 01, 2009 | HP Pavilion dv6000z Notebook
Taskbar is on the right side of the screen and not at the bottom. how do i move it back to the bottom
Click you left mouse button  while pointing in the gray area of the taskbar now move the mouse while holding down the button dragging the task bar back to the bottom.
Nov 24, 2008 | HP Pavilion dv6000z Notebook
HP Compaq 6510b Notebook PC Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
