Question about Sony DCR-HC26 Mini DV Digital Camcorder
Type of unit:Sony Handycam (DCR-HC26)I have a couple...1)when trying to insert a DV cassette,the door will not shut.2)The buttons on the touch screen won't work either.
    Genius:
  • 1,812 Answers
The most likely cause for the buttons not working is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. The tape mechanism is another story.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Nov 04, 2010
DCR-HC26 Will not play/rewind/forward.Tried 2 identical cameras and cassetes. Nothing works.
Have you ever heard the silly phrase: "If everything else fails, read the User Manual"?
Please look on P. 23 where it says ... or better yet, here's the picture :-)
dcr-hc26-will-not-play-rewind#solution-section-izwbjt2504mgx4k4p1sstn4i-1-0.jpg dcr-hc26-will-not-play-rewind#solution-section-izwbjt2504mgx4k4p1sstn4i-1-2.jpg
Dec 22, 2014 | Sony DCR-HC26 Mini DV Digital Camcorder
Repair handycam touchscreen
It should be the first screen you see when you turn it on, if it has not been set. This is an old camera, so the internal rechargeable battery that saves this info may be dead.
here is the manual in pdf if you don't already have it.
https://docs.sony.com/release/DCR-HC26_Instruction_Manual%5B1%5D.pdf
Dec 27, 2013 | Sony DCR-HC26 Mini DV Digital Camcorder
My sony handycam DCR-HC26 is frozen on "clock
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body or the LCD module itself and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Feb 01, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony dcr-hc26 touch screen does not work
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 30, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My SONY HANDYCAM DCR-HC26 touch panel is not working n m unable to forward,rewind,play,or do anything...how do i fix this problem..plzz help..its urgent...
Most likely, the flex cable that runs from your LCD to your main PCboard is bad. The only thing that you can try to do is flip your LCD around and against the camera. See if the touch screen will work then. The camcorder will still need to be repaired by an experienced technician at some point.
Hope this helps.
www.austintelstarservices.com
Oct 02, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
My sony DCR-HC26 TOUCH SCREEN NOT WORKING
it's not exactly the same, but this website shows a pretty foolproof way on how to fix it on a different camera.
http://www.agoraquest.com/viewtopic.php?topic=33427&forum=32&start=10&select_page_number=2
i fixed the touchscreen on my hc26 with it on the first try. i put a piece of paper folded a couple times under the ribbon cable connections where it meets the screen (against the plastic frame for the screen, under the blue cable), and put a piece of cardboard against the circuit board to give it more pressure from that side. works like a charm!
Jan 26, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony Handycam DCR-HC26
don't expect any help from sony, they are too lazy to take the time, i'll never buy sony again
Aug 20, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony DCR-HC26 Mini DV Digital Camcorder Logo
144 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
