Question about Samsung LA40R81BDX 40 in. LCD TV
MY PICTURE SETTINGS KEEPS RESETTING ITSELF AFTER ABOUT 40 MINS.
I have got a Samsung LE40R88BD 40in lcd tv that after about half an hour the screen goes black and then comes back on after about ten secs but the picture is very much darker. what is the problem?
Posted on Nov 20, 2010
My ultra hdtv 40-500 works for 5 mins then dish logo flashes and no visual
Hello, if the "Dish logo" flashes then no picture, it sounds like a Dish receiver problem not a tv set issue. Try hooking up a dvd player to it and see if it works. If it does, try resetting your Dish receiver. Thanks....Terry
May 25, 2014 | Televison & Video
Reset to Dec 31
Try activating auto-update time in settings
Feb 08, 2014 | Samsung Star 3G GT-S5603 (16 GB) Cell...
White smoke after motor warms up.. smells like fuel
could be injector pump settings engine getting too much fuel try resetting computer disconnect batt for 5 mins then reconnect might reset itself
Jan 03, 2014 | 2001-2003 6.6L DURAMAX DIESEL HOT...
My Samsung LNT3253H LCD TV has suddenly started changing its own settings (e.g. picture mode keeps switching to ''dynamic'' and the ''light effect'' keeps setting itself to ''always on''). Any thoughts on...
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Sep 05, 2009 | Televison & Video
Audiosonic KMCTH68 Keeps turning itself off after 2 mins
CHEAP TV VIDEO REPAIRS
Can't be 100% sure but the most likely cause of the problem is bad solder connections in the switch mode power supply or on the vertical output IC, or anywhere on the main or picture tube circuit boards, due to age and switching on and off TV's develop bad solder connections when cold the connection is made and when it warms up due to heat expansion the connection breaks, you will need to be handy with a soldering iron, and discharge all power supplies with something like a 100 Watt globe before soldering or you may blow things up and do really serious damage, and be warned TV 's have very high voltages 360 volts DC in the SMPS primary and over 20,000 volts to the picture tube, so be careful.
Feb 03, 2009 | Panasonic PT-40LC12 40" Rear Projection...
My Epson R1800 keeps resetting itself
You have done all the usuall checks, but you may have a usb power problem, try the printer without any other usb peripheral in and see if it stays connected. If not, then the usb connection or workings in the printer may be faulty and keeps disconecting, hence the bing bong as it re connects to windows. You may have faulty hardware, leave the printer disconnected from usb and mains for 15 mins or so then try again.
Mar 18, 2007 | Epson Stylus C86 InkJet Printer
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Samsung LA40R81BDX 40 in. LCD TV Logo
769 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
