Question about HP Compaq Evo n610c Notebook
Evo n610c laptop battery not charging
Evo n610c
it says upon start up: 103 charge circuit failure
the battery does not charge
waddoo i do ?
My Compaq Evo N610c says that window could not load installer for battery. I should contact my hardware vendor for assistance
Posted on May 09, 2013
    Genius:
  • 2,028 Answers
Time for a new battery.
Posted on Jun 13, 2008
Compac Evo N610c - 2Mhz - 1 GB ram - Windows XP SP2 Blinking charging light went out and computer won't start up again. Checked power suplly (18,57v dc) Replaced with another power supply, replaced the...
Your computer has an open circuit on the system board. If you have data on the machine you can remove the hard drive and connect it to a PC, Sorry I can't think of a more elegant solution. I hope I'm wrong.
Mar 11, 2011 | HP Compaq Evo n610c Notebook
My compaq Evo n610c my battery wont charge when on ac power.The light for when the battery wont go on.
sounds like your DC coonector came loose from the system board.it is a common problem with laptops,
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
here is how to repair:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 26, 2010 | HP Compaq Evo n610c Notebook
Compaq evo N610c problem charge Circuit Failure
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 14, 2010 | HP Compaq Evo n610c Notebook
I have a sony evo n600c and when it starts up its says 103 charge circuit fails does and the battary does not work i know i will need another battery but what i am asking is is the 103 charge circuit fails...
This error is commonly seen in Compaq laptops. Take out the battery,start the laptop with the adapter only and see if that error message pops up again and if not then it might be your battery.Usually battery life is 3yrs. Put the battery back again and see if the message pops up again. Try the battery on a different laptop. It could be the Voltage Converter Board...see service manual for the same or call Compaq service centre.
Jul 28, 2009 | Compaq Evo N600c Notebook
Laptop Compaq N610C did not powered ON
Remove your battery - start the unit on A/C then after booting up refitted battery.
Jan 21, 2009 | Compaq Evo N610C Notebook
Sir, When i Trun On the Laptop, N610c the charging (cell) ligh blink 4-6 times. but laptop did not start i put it on charging by connecting it with charger charging light turn on contineously and when i...
Remove your battery and install the a/c connector - power the unit up then when inside windows refitt the battery - examine the condition in control panel >> power options >> you may have a dead cell in the battery.
LOSSING CD DRIVER COMPAQ EVO N610C
The problem with your system is that the Battery you are using is Faulty is either the current voltage spoilt it or may be is an old age battery
What you will have to do is to get another Battery that you will first of all Charge it well before usage ok. nice
Sep 23, 2008 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Battery not charging
I would advise you to try this:
1......Make sure the unit is completely off.
2...........Hold down the "FN" key and turn the unit on with the main sliding Power switch and immediately start to tap the "F11" key.
3.............The unit will look likes it's shutting down. Let it do this three times.
This resets the CMOS. On first boot, the POST will check the RAM and inform you that changes have been made. Accept the changes.
This also resets all of the information in the BIOS to the defaults. If you have made changes (security passwords, asset numbers,etc.) enter the BIOS first and record all these settings so you can restore them afterwards.
Jun 10, 2008 | HP Compaq Evo n610c Notebook
Dont worry you can go through your problem by visiting the link below-
http://ftp1.us.dell.com/diags/R66243.htm#s1
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 28, 2008 | HP Compaq Evo n610c Notebook
HP Compaq Evo n610c Notebook Logo
321 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
