Question about Epson Stylus CX6000 All-In-One InkJet Printer
Epson stylus dx6000
my printer has just stared missing sections out when printing it has been fine up to today i have changed the ink cartridges but this has made no difference and have run the printing tests within the tools section with no luck
any help appreciated
thanks kathy
  • Anonymous Feb 20, 2009
    i have the same prob but when i try to clean the heads it says "cannot clean the heads."
    oh really? now, thank you very much! what the hell can i do in such a situation?
  • 94 Answers
Hi, its unfortunate that you've experience that issue with your printer. The best possible solution that we can offer to you is to run a series of head cleaning. Just to make sure that you have try the most effective head cleaning please use the maintenance or utility section of this printer. After each head cleaning you need to print a nozzle pattern just to confirm it the head cleaning is successful. After third head cleaning and the issue still present. Reseat the ink cartridge. If issue still present after trying those steps, it only means that you need to call your printer manufacturer and ask for service referral or exercise the warranty options of your printer.
Posted on Jun 12, 2008
Epson stylus dx6000 error message e-02 have tried
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Oct 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
My DX6000 ha s blocked jets that no amount of using "clean print heads" cures. Is there anything I can do to get it working properly again?
I recommend checking how long you have had the cartridges in the printer, anything over 6 months and the ink can start to clot and up in the cartridge, if this is the case this would render head cleaning useless until you change the cartridges.
If you use third party inks try using Epson inks, they might be expensive but they are designed to be used with the printer and contain the proper cleaning fluid.
You can use cleaning cartridges but these tend to do more damage than good as the fluid is a corrosive which can eventually damage the print head.
If your feeling daring you can remove the print head from the printer and soak it in some distilled water over night, if this fails it will be a replacement printer. If your not daring Epson have got repair centres where you can take the printer to be repaired, it might be worth comparing the price of a repair to a new printer.
Jan 27, 2010 | Epson Stylus Multifunction Printer/...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Keep ink cartridges out of the reach of children and do not drink the ink.
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Black and Magenta ink won't print...
Do a deep clean on the printer.
Done from the printer setup.
widows is done from start, printers and faxes, click on your printer.
Should bring up window for setup.
Look for cleaning section.
May 07, 2009 | Epson Stylus C88 InkJet Photo Printer
Changing ink in Epson DX6000 printer
Normally, you lift the scanner/copy bed up while the unit is on and then the cartridge moves to the center.
Have you tried this and if so without success? let me know so I can find the secret if there is one for you.
Jan 28, 2009 | Epson Stylus DX4200 All-In-One InkJet...
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Aug 09, 2008 | Office Equipment & Supplies
Ink cartridges
didnt see any c46 listed on the manufacturer website. sure you put the right number down?
How old is this printer?
Oct 20, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
