Question about Coldtech COL-J6SFF61B Solid Door Freezer Six Half Door Freezers
What type freon is used in this freezer? - Coldtech COL-J6SFF61B Solid Door Freezer Six Half Door Freezers
    Guru:
  • 1,524 Answers
R-404A Coldtech is now Ascend.
Posted on Nov 02, 2010
What freon to use
Hey friend, thank you for the post!
I understand that you are searching for what type of freon is used in your Frigidaire freezer, FFU14F5HW. Based off of that model the freon would be 134A. Hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire FFU14F5HW Frost Free 13.7 Cu....
Side by side Whirlpool in insulated cold garage ompressor seems to be running all the time, freezer not working fridge is warm
Sounds like low on freon. Some refrig. has a charging port. It may even say on name tag what type of freon to use. You need a guage to check if unit is low on freon.
Jan 20, 2014 | Gladiator Freezerator Top Freezer...
What is total charge for up right freezer
Hello jharrislaye -If you are referring to approximately what the retail price is for this particular product, unfortunately base on the age of the unit, that information is very difficult to find. However, similar units manufacture nowadays is roughly about $700.00-$1,000.00. If you are speaking about a Freon charge, that would be base on the type of Freon the unit requires and on the actual service technician providing the service. You may locate information regarding the Freon on the serial tag, which is typically located inside the cabinet on the left side wall.
Jun 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer is not freezing. Is cold only.
The problem which you mentioned is related to faulty/ weak compressor.--------- I will explain with more detail.------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jun 28, 2011 | Refrigerators
Ice is forming on bottom and back wall of freezer can any one help with this
there are two types of freezer, one is upright freezer (same as refrigerator on outside look but inside all the layers are same as the freezer of an ordinaryrefrigerator) the other one is the chest type freezer(basically it looks like a chest cabinet),now about the forming of ice at the bottom and back wall, well should be all side of the freezer should have ice on it,
Just one question to ask? Did you used any sharp object in removing ice(ex. knife, ice pick , etc,)
If you do then there are a possibility that you do some hole on the tubes where the Freon Gas (chemical refrigerant) are passing thru, then in that case you might have leakage. Well that means you really need to call a technician to do the job, because you'll gonna need to fix the hole and re-charge a freon gas.(having not enough refrigerant on the system, your refrigerator might not able to produce ice completly.
The other possible reason is that your motor compressor might be damaged(possible reason: Lost compression) it has something to do with pump compression inside the motor (only technician can solve this problem)
Oct 31, 2009 | Refrigerators
I have just bought an old kenmore freezer
could be freon to plugged freon lines probably not worth the cost of a service call and if it's that old it uses r-12 freon very expensive .Tom
Jun 15, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Need to know what type of freon to use to recharge a one yaer old Beverage Air Sandwich table refrigeration unit. Is this the same process as recharging an automotive AC system?
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Mar 29, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Technition called it freon noise
Sounds really strange to me. Not sure what kind of patch he could have used. I've never heard of "freon noise". Clicking and popping could be the thermal overload tripping and resetting. The unit should still be under warranty. I would contact them to get another tech and another opinion. It would be best to get this resolved before the warranty wears out.
Jan 02, 2009 | Maytag Freezer MQU2057
Coldtech COL-J6SFF61B Solid Door Freezer Six Half Door Freezers Logo
115 people viewed this question
Top Coldtech Refrigerators Experts
Randy Justice
ray gallant
Tom Chichester
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
