Question about Weather King Heating & Cooling
Air conditioner blowing hot air and no suckson in the return unit, we had a guy we know came over tuesday and put freeon in it and cleaned the out side coil and it blew colder aie but today is a different story please help me
    Scholar:
  • 54 Answers
Well from what you've said I'm afraid it sounds like you have a significant refrigerant leak that needs to be repaired by a qualified professional. Heres how it's done: Any remaining refrigerant is removed from the system and stored in a tank with a refrigerant recovery machine the system is then pressurized with dry nitrogen and a trace amount of refrigerant. You look for the leak visually by looking for oily spots along the refrigerant circuit with soap bubbles to pinpoint the location in conjunction if needed with electronic leak detector leaks can also often be run down using sonic detectors and florescent dye with a black light. When a leak its repaired the procedure is repeated until all the leaks are all found and repaired and the system holds pressure over a period of time the system is then pulled in to a deep vacuum, the amount of oil lost with the leaks is estimated and replaced, the system is pulled into a vacuum again and then charged to provide the appropriate superheat specified by the compressor manufacturer It can be very tedious, time consuming and expensive so be prepared.Sorry for the bad news Hope it works out for you.
Posted on Jun 12, 2008
Kia air conditioner doesnt work
I have a 2007 kia rondo.Ac was working,parked it for a year,ac wasnt working,recharged,the ac,it worked for a month,an started again,blowing hot ai.If you let it set for hour would start working...then after a few days it would only work early morning,if you dont turn ac of,then it stop working,I see the clutch isnt kicking in,ir you try an put freeon in it soon as you start putting it in it would kick on.An its full of freeon.
Mar 11, 2012 | 2007 Kia Rondo LX V6
When i shift from park ti drive my car jolts what a/c blows hot
your A/C most likely blows hot air because it is out of freeon. take it to like auto zone and get them to check the freeon level and if its low you can get it recharged.
Jul 10, 2009 | Heating & Cooling
AIR CONDITIONER ON 2002 JEEP LIBERTY IS LEAKING FREEON SOMEWHERE IT WILL COOL FOR FOUR DAYS AFTER CHARGING WITH FREEON AND THEN IT BLOWS HOT AIR. NO LEAK VISABLE WHEN I ADDED FREEON DYE. WHERE COULD THE...
its probley leaking in the evaporator you cannot see it without removing the dash see if anyone that you know has a freon sniffer then lacated the drain tube for the evaporator case most of the time its located on the fire wall on the right lower area with a full charge use the sniffer and see if indicates a leak
Jul 09, 2009 | 2002 Jeep Liberty
After boost air conditioner started blowing hot air
BLOWING HOT AIR YOU MAY HAVE A RESTRICTION ON THE SYSTEM, OR MAYBE A REAL BAD LEAK THAT UR FREEON IS ALL GONE,
May 28, 2009 | 2006 Chevrolet Trailblazer
Home Air Condition cooling problem
Hello. If your outdoor coils are dirty it's a good chance the indoor coils are dirty also. Clean the indoor coils and flush out the condensate line.
I know it's tempting to feel the air and try to decide if the unit is working properly but, you need to use a thermometer and while the unit is running check the temperature at the return air vent and then check the temperature at the supply vent closest to the unit. Remember to let the thermometer set for about 5 minutes before reading.
You should be looking for about 15 degrees F cooling between the return and supply.
If your coils are clean make sure the outdoor fan is operating properly. The air coming out of the outdoor fan should feel warm, almost hot. If not you may need to check your pressures. Good luck and let me know what you find.
Feb 03, 2009 | Ruud Central System Air Conditioner
Air conditioning unit
Hi! AC Unit
Sorry you have had so much trouble. Sounds like with the factory warranty being in effect the whole outside condensing unit should be replaced. With this type of problem there could be some blockage in the AC lines. With out some pressure reading it is hard to tell if the expansion tube is plugged, or there is some other major problem. If your service tech is unable to diagnose the problem you may need to get a third opinion. Goodman may have a factory representative in your area. You may be able to find some help with a different dealer or online. Good Luck! I will try and look for any changes.
InMrFxIt
Jul 28, 2008 | Goodman CLQ36AR49 Air Conditioner
Doesn't blow hard anymore
First make sure unit is correct for the size of room. You may have to mount it permanently so that it's tilted so it drains out the window. Check freeon level.
Jul 15, 2008 | Haier hwr10xc6 Air Conditioner
AIR CONDITIONER COMES ON BUT DOES NOT BLOW COOL AIR
It is possible that your unit needs refrigerant but Before I would have someone recharge it they would have to locate the point of leak and repair it. I would check to make sure it is not some other problem first, like is the compressor operating.
Jun 15, 2008 | Maytag M6P09S2ACOM Air Conditioner
Heating & Cooling Logo
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
