Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
I think its a bad chuck unsure though
When u hold the chuck it makes a grinding sound and it doesnt lock tight it keeps spinning
  • jmtomli Jun 12, 2008
    please help thank you
  • 254 Answers
Yeah you have a bad chuck. there is a screw inside the receiver of the chuck if you remove this screw the chuck will come off. Reverse this procedure to re install the new chuck.
Posted on Jun 13, 2008
How do I get the chuck off a hole hawg drill if shaft keeps spinning due to broken shaft
I'm not sure about that specific tool, but usually a keyed (or keyless) Chuck has a screw hidden inside of it. Open the Chuck all the way, and shine a light in. You should see a screw down there. It'll be left hand thread (clockwise to loosen). Remove this screw, and then get the biggest Allen wrench you have, and lock the short end of the allen wrench into your chuck so it acts like a lever handle. Use a hammer to whack the Allen wrench with one swift blow to break the threads loose that hold the chuck on. You may need to find a way to hold onto the shaft to keep it from spinning. This might involve removing the case to find a purchase to hold onto with some locking pliers. If the shaft is completely broken, and loose from the drill, stick it in a vice to hold before trying to remove the screw, and the chuck.
Try googling "removing drill chuck", and you should find some comprehensive videos on the subject.
Good luck.
If you need more help, post some photos of what you're working with, and I might be able to give you a better answer.
Aug 02, 2015 | Drills
Tool piece stuck in chuck, unable to unlock it. Can you help
I would suggest contacting one of our Factory Service centers so we can take a look at it. Please see the link provided. DEWALT com
Mar 16, 2015 | Dewalt DC759CA 18-Volt Compact...
Top chuck just clicks but won't change bit size?
It sounds as though you will have to replace the chuck. Remove the screw (l/h tread) from inside the chuck first before removing it.
Feb 02, 2013 | Drills
Btd 140 rfe chuck not spinning true
The usual reason for major wobble of the spindle is a worn gearcase. It can easly be replaced. Any good repair agent can do it. If you want to do it yourself. Simply remove the circlip holding the chuck sleve on then take off the washer, spring and balls. release the light unit from underneath and take off the locking block. The gearbox cover will then unscrew (but can be tight) I think it is lefthand thread.Check spindle for wear and lubricate the bush bearing in the new gearcase, then rebuild in reverse mode
Jun 17, 2012 | Makita 18V LXT Lithium - Ion Cordless...
Cant get the bad chuck off my RIDGID 18v cordless hammer drill
The chucks on these drills are put on not only VERY tight but usually with some lok-tite to boost so they don't come off easy. In my shop we usually lock a 1/2" hex driver in the chuck and use a 1/2" impact wrench to knock them loose. It usually takes a few seconds to come loose. Another method is to lock the short end of a 1/2" allen wrench in the chuck so that it sticks straight up with the drill standing up. Then lay the drill on its side with the top at the edge of your bench and the allen wrench sticking over the side of the bench. NOTE: The chuck follows the lefty-loosey, righty-tighty rule, the chuck screw is reverse thread. Have someone firmly hold the drill and then hit the end of the allen wrench until the chuck comes loose. Once you break it free it will spin off easily. You do need to put the new one on with lok-tite and as tight as you possibly can then lok-tite the screw and tighten it as much as you can by hand.
Jan 20, 2012 | Ridgid Drills
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
I don't know how to change the grinding blade on my makita angle grinder.
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
The racheting sound is the result of the torque setting indicated on the dial before the chuck. Set the dial to the drill bit icon, or all the way past the highest number, and that locks out the torque...
Is the ratcheting sound when you are using it to drill or when you use the drill to tighten the chuck. If it is when using to drill then the gearbox might be bad, how much movement is in the spindle. Hold the drill and move the chuck up and down and any excessive movement could indicate the gearbox might be broken in half. If it the chuck when tightening some of their chucks have a click type of noise especially when newer. Let me know and I will try and help more if you need it.
Sep 03, 2009 | Panasonic EY6409GQKW 12 - Volt, 1/2"...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
313 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
