Question about Canon PIXMA MP830 All-In-One InkJet Printer
Lines are crooked
I too was getting the 5100 error, that's been solved but I still get broken lines and squiggly letters. We print a lot of invoices with lines so my printer is practically unusable. Any suggestions?
    Problem Solver:
  • 7 Answers
Right, this problem sounds like it might be something you can fix easily, firstly check through your printer menu and you should find an option such as allignment test page, select this and it will go through a cycle printing off various pages to make sure the cartridges are correctly alligned, if this fails then it could be a dry rail, this is the rail that the cartridges run along, run your finger along this (for safety do this with machine off) and if it fells like there is a lot of friction then simply add a drop of oil (oridinary car oil can be used) and spread across the rail. if this fails then please let me know
Posted on Jun 16, 2008
When i try to print it says error 5100 and will not print
Error Code 5100
It can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. The purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Canon PIXMA iP1800 Printer
Canon i255 printer error 5100
5100 is a carriage error. check the timing strip for contamination (plastic strip about 1/4" in width). Check for obstructions.
more information on this error can be found at http://www.fixyourownprinter.com/forums/laser/25975
Jul 12, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
Printers lines are squiggly
calibate the print cartridges
if not solved then clkean encoder strip ( a thin Clear Strip )
check Carriage movement Belt , If REquire Replace
Feb 04, 2009 | HP DesignJet 750c plus InkJet Printer
Error 5100 repeated
hi! try other remedy. for example, placing the usb connection behind your cpu instead on the front, if still didn't work out, try to uninstall your printer driver then reinstall it, then restart. the broken line that you've seen and the reason why it doesn't print smaller font size is due to 1. low ink 2. the nozzle was clog (better clean it) 3. it needs replacement of cartridge to a new one. don't panic, relax, okay?
Dec 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
HP 7410 Paper Feeds in Crooked
The paper size in the feeder and the paper size in your printing properties have to match.
I.e. if your printing format says "letter size" and in your feeder is legal or A4 paper you will get this error.
Please reply if this does not help.
Dec 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printing problem with my invoice and estimate
MyInvoices & Estimates Deluxe
Open Company file error.
Exception: Unable to load DLL 'sqlceme35.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Jul 27, 2008 | Avanquest My Invoices And Estimates Deluxe...
The blinking light
Hi, The problem your having with the two circles and the squiggly line mean you have a paper jam. Hope this helps!!!!
Dec 05, 2007 | HP LaserJet P2015dn Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
292 people viewed this question
old marine
old marine
