Question about Datamax DMX I-4206 Printer
Improving bar code image DPI for a darker output
I received a e-mail with a bar code created with Adobe.
Datamax cannot read the format, so i can only print the bar code using
windows, windows does not give a dark enough image.
I need to be able to convert the format so i can print from within Datamax
I tried to increase the dpi for a darker image from windows, there was no
improvement.
  • 155 Answers
Datamax Program Language (DPL) uses pcx and bmp graphic formats. The Adobe image must be opened in Adobe Reader and print using a windows driver. Use the datamax windows driver from www.seagullscientific.com
Posted on Apr 05, 2009
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Tip
How do I create custom Barcodes?
<p>Barcodes can be printed symbols with encoded data will be charged to the computer via a scanner. A bar code allows a company to maintain control of their actions to secure and instant access to information about each product. A bar code is created using software barcode generation software. Customizing a bar code is a simple process to enter your data into the software program, and print.<br /> <p> <br /> <p>1. Open your Web browser and visit Barcode Generator, barcode or Soft. See the program's interface is usually presented on the homepage of the website page. Look at the list of different types of bar codes available, and click the type of barcode you want to use. <br /> <p><br /> <p>2. Locate the area where you are allowed to present the information is converted into a bar in, and within the data type. Click "Generate Barcode" to create barcode images. View the image resulting bar code, right click on the image and click "Save image as" in the drop-down menu to save the resulting image on your computer. <br /> <p><br /> <p>3. Close the program bar code generation, and open the bar code image stored on your computer. Right click on the saved image and click "Print" from the output drop-down menu to print the bar code. Scan the bar code information printed to be loaded on your computer and check the data sent to make sure it is correct. <br />
on Jun 26, 2011 | Computers & Internet
Setting dpi on my nikon d3100
DPI (dots per inch) is an output specification and is irrelevant to the camera. The camera puts a value into the field simply because it has to put something there. The DPI is set by the printing program when it prints a picture. A picture printed at 4x6 will obviously have more dots per inch than the same picture printed at 8x10.
Nov 30, 2012 | Nikon D3100 Digital Camera
I can't read a code bar printed with datamax a4212
try adjusting your darkness settings. if too dark wont read and also if too light wont read. also try a printhead test to make sure no elements are burnt out.
Aug 13, 2017 | Computers & Internet
My samsung gt-c3530 mobile does not show jpg images copied from my laptop. what could be the problem
As this handset is an old model you need to check the manual for the supported file format, and resolution support. You can check the DNS settings from your service provider.
May 02, 2011 | Samsung SGH-a437 Cellular Phone
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
Need to get scanned photos to between 300 and 600 dpi
What I saw first off is that although the resolution indicates 96 DPI, the file size itself between the 2 examples are drastically different. You are putting raster images into MS Word for publication work, and that is a NO NO. Word was not created for any kind of high resolution printing. It's a glorified text editor that people seem to think is an option for printing. YOU WILL NEVER GET 300 or 600 DPI images out of Word. Ever.
To create your project for printing, you need to use software more suited for the task. InDesign and Quark are examples, but they are very expensive. In my opinion, Publisher would be better for this kind of project and I hate myself for saying that.
Talk to your Printer, find out his specifications for Applications and Linescreen for Printing. The minimum requirement is 280 DPI, but if the image is placed at 100%, 600 DPI is overkill.
Oh, and try to never scan a scan... you are looking for trouble... a little thing called a Moiré pattern comes into play, and it will make you images print NASTY!
I could go on about your post all day long, but if there is anything else I didn't explain, please post again.
Jan 21, 2009 | MGI Software PhotoSuite SE V4.0
Doc chnages required
You can't.  You could try loading the Adobe professional software, but I do not think it lets you edit PDF's
If the Doc contains words you can OCR (Optical Character Recognition) it (ie read it) edit it an dthen create a new PDF.
Jan 14, 2009 | Microsoft Computers & Internet
I created a logo using Adobe Illustrator 10 and drag and dropped it in a Photoshop 7 file to be printed. The photoshop 7 file was 300 dpi and when I brought the logo in in got really small so I increased...
Resolution is a hard thing to grasp. I'm guessing the original logo created was either a low DPI and/or a small physical size. For example if you create a 1in x 1in logo at 300 DPI and increase the size to 4in x 4in at 300 DPI - the image does not contain small enough pixels to give a quality image (1 pixel is translated to 4 giving jagged edges). I hope this helps.
Dec 18, 2008 | Computers & Internet
Reduce Photo
You can use Photoshop to reduce Photo size to a minimum size that can be mailed and u can retain the resolution by it. Its afantastic application. Open your image in photoshop and right clik it on the top of the title bar choose image size and change the resoution to 150DPI or lessere but not less than 72 DPI.
R u can go to save as command in the file menu and save it for Web option is better to reduce the size of the image to very smaller one which can be mailed.
Thanks
Nov 09, 2007 | Adobe Photoshop 7.0 for PC
Datamax DMX I-4206 Printer Logo
250 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
