Question about Indesit WA 115 Front Load Washer
APPEARANCE OF SCUM
HI MY SISTER JUST PHONED ME FOR A POSSIBLE CAUSE & SOLUTION TO THE PROBLEM OF SCUM BEING LEFT ON THE DOOR SEAL & WINDOW OF HER MACHINE.ITS A PROBLEM THAT STARTED ABOUT 2 MONTHS AGO,SHE HAS TRIED NEW DETERGENT EVEN USING CALGON.THE MACHINE IS ABOUT 3 1/2 YEARS OLD AND WORKS PERFECTLY BUT SHE WOULD LIKE TO STOP THIS SCUM PROBLEM.CAN ANYONE HELP PLEASE.MLB
  • d358 Oct 06, 2008
    I have a Whirlpool washing machine. After each load I get scum around the agitator and the top of the tub. I tried different detergents no help. It is getting on my dark clothes and leaving scum on them Help!!
  • 76 Answers
Hey there...
The only thing that can cause this is the filter is blocked, or its needed of a service....
Its not that big a deal but its something in all front and top loaders, it needs a good service at least once a year...
Hope this helps you.
Wouter...
Posted on Sep 10, 2008
Why and how to get rid of smell on clothes with a kenmore He2 front load washer
Hi. inside the door seal is a lip that will grow mold or some kind of soap scum that turns black. pull back the edge of the door seal and wipe out with spray bleach ( wear gloves ). Leave the door open a little when you are done using it and that will help to let it dry inside.
Good luck
Aug 24, 2014 | Kenmore HE2 Plus Front Load Washer
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
What is the solution for error 4 appears on autoclave little sister 5
Visually check for obstructions on the door seal area. Clean gasket and its mating face. Run Cycle again.
May 25, 2014 | Science & Laboratory
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How to stop dishwasher from leaking out of the bottom left corner?
follow the next steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenses ed19f28b-0f72-4aa8-a09e-69699854be01.gifgasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Jul 06, 2013 | Dishwashers
There is residue left on dishes after wshing and a whitish film on the dishwasher door. Looks like mineral deposits. My rinse aid dispenser has stopped working as well. Could this possibly be solved by...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;'';
Apr 03, 2011 | KitchenAid 24 in. KUDS25 Built-in...
Hello - I have a Bosch Classixx 1400 and it smells bad! What may be causing this? I have emptied the black tube with water in adn I have unscrewed the plug on the right and water came out of here but the...
Hi.
The smell will be coming from inside the drum as you summised.
It is probably caused by the drain in need of cleaning, or more likely a build up of dirt and scum on the door seal cased by doing too many low temperature washes.
Check the seal carefully and if it is stained black, then the only real solution is to replace the seal, and do more high temperature washes
Jan 16, 2011 | Bosch Washing Machines
Dishwasher leaking
This sounds like a hinge problem to start with.
Test the seal by dragging a strip of paper through it with door closed. Probably that left hinge isn't holding door close enough which was probably the original cause. As seal dries out a bit then will leak.
At this point I would investigate the hinge possibility AND if possible a DIY fix. It may be loose mounting screws or take a little shim to hold the left corner tighter. I would not waste money for a service call.
You probably might need to release the door balance springs accessable under the toe kick area while working on the door. Possibly a hinge is bent.
You might do as they do in the auto industry when a door doesn't fit... basically put forces on it to bend it a bit. In your case it would be to distribute the load and support the door when horizontal about 6 inches out from the left hinge and then bend the end of the door down to bend the hinge mounts slightly..
Then check the seal clearance with the strip of paper as you do with a refigerator seal by cloosing on a strip of paper and dragging the strip to see if it is gripped.
May 13, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
Dishes do not get clean- residue remains
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Dec 22, 2009 | GE GLD5900NWW / GLD5900NBB / GLD5900NCC...
Indesit WA 115 Front Load Washer Logo
83 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
