If you can get the door open.
There is a reset button on the hinge side of the inside of the door.
Press the reset button, and then you have about five seconds to enter your new code.
Test the code with the door open!
That way, if it does not work the first time, then the doors is still open, and you can do it again.
Warning: Place fresh batteries into the battery compartment before doing this, or you will just get locked out again.
If, you cannot get the door open, and your keys are locked in the safe, then call Harbor Freight.
Call Harbor Freight:
Technical
& Parts (Safe Keys) 1-800-444-3353
Give them the key code number. (it is located on the key insert, where you stick the key in the lock)
It takes about two weeks to get a new key/keys.
