Question about Panasonic DMR-E85H DVD Recorder
Why won't the DVD play on my computer? Help, please?
I just bought the Panasonic DVD-RAM re-writeable disc and recorded stuff onto it. The disc plays fine in the DVR but when I put it into my computer, there are no files. Help?
  • Anonymous Jul 11, 2008
    Same problem - Panasonic recorded DVD isn't recognised by computer. How do you finalise the DVD in the recorder? Baz
    President:
  • 624 Answers
Put it back in the recorder you made it with and make sure it is finalized. Also make sure your DVD drive in your computer is compatable with that format.
Posted on Jun 16, 2008
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
PANASONIC DVD RAM DISC RECORDING
Hi and welcome to FixYa,
To my knowledge the only basic requirement to play a recorded disc into another machine (even of the same brand) is that the disc must be finalized. The recorder must be instructed that no further recording is intended and that the recorded disc wold be in use externally (some other standalone player).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 23, 2008 | Televison & Video
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
Why doesn't DVD disc play on my computer?
Hello again
I don't know what gear you are using or exactly what you want to do, but I assume you want to put some of your old video vhs tapes or something you have borrowed, on to your computer.
Your DVD/HDD recorder will probably support DVD-R as well as DVD-RAM unless you are very unlucky. If it's a Panasonic it will definitely support DVD-R. DVD-R are reasonably cheap these days so you could use them for recording instead of DVD-RAM, then easily play them on your computer's drive. You would have the added advantage of a back up disc as well. If you want to edit first, use the HDD on the highest quality setting then transfer your edited work to a DVD-R..
Alternatively, you could buy an external dvd drive for your computer that supports -RAM, such as Icy Box or similar. External drives are reasonably priced and if you plan to transfer a lot of video, it would be a worthwhile investment.
Yes, you could probably connect the DVR direct you your computer but you would need an appropriate media card plus suitable software.
Good luck....hope this helps...
Jun 12, 2008 | Panasonic DMR-E85H DVD Recorder
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Dvd-ram 4.7gb
DVD RAM discs don't need finalised, hence its not an available option.
They will play directly on other players -*** BUT*** ONLY DVD
RAM players.
Don't expect your RAM disc to play on a normal
DVD+/-RW DVD +/-R device. Its not going to happen unless the
device supports DVD RAM also. If it does, it will play your RAM
disc once you've finished recording in your own DVD RAM
recording unit. Pop it out of your unit, straight into the other, and
the jobs done.
Nov 02, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Are there any DVD players/recorders that will play back both DVD-RAM and DVD-R discs?
Yes. Although at the present time most DVD players only support DVD-R playback, Hitachi’s DVRF7U will play back both DVD-RAM and DVD-R discs. In addition, there is a growing number of affordably priced DVD-RAM players that support both of these formats. These devices make it very simple and convenient to enjoy the robust capabilities of re-writeable DVD-RAM discs.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Panasonic DMR-E85H DVD Recorder Logo
215 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
