Indesit wg1030 does it have a pump filter and where is it? water won't drain out and i'm trying to see if this is the problem... cheers, andy
  • Anonymous Dec 27, 2008
    indesit wg1030 does it have a pump filter and where is it? water won't drain out and i'm trying to see if this is the problem... cheers, andy
5 Suggested Answers
SOURCE: indesit washer dryer
We just had the same problem and it made a horrible noise when the pump was trying to work, then it stopped altogether and nothing was happening. We were able to get the door open after several minutes, remove the washing, detach waste pipe to release water, remove the kick panel on front, remove the filter and release the rest of water. It turned out there were two hair grips stuck in the part that turns inside the front there. We removed them and turned it back on and it works great! Saved us at least £32!
Posted on Oct 17, 2007
grandadfixer
  • 99 Answers
SOURCE: Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Posted on Oct 11, 2008
futureloginn
  • 734 Answers
SOURCE: I have an Indesit washing
hi there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it
doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn,
replace it--but be sure to check the pump pulley before you change the belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
and may not function at all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
the washing machine main housing near the door frame. Often you have to raise or open the top
or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the
motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing
machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to
burn out in one direction and continue to operate in the other. If this happens, you need to replace
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the
unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during
the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch
prevents the spinning action when the lid is up.
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Posted on Dec 12, 2008
  • 157 Answers
SOURCE: wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
Posted on Dec 19, 2008
buffalonyman
  • 1865 Answers
SOURCE: My indesit IWME12 won 't spin or pump out and there
Unplug the machine for a few minutes to reset the controller, then replug
Posted on Sep 08, 2009
Indesit WLA111 stuck on rinse cycle
There is a drain plug and filter under the drum. You access it from the front by taking the panel under the door off. Get ready for lots of water to come out when you take the drain plug off. Clean out the area of the filter and drain plug.
Feb 10, 2014 | Indesit WA 115 Front Load Washer
Door won't open
Has all the water drained out, some machines won't let door open unless all water drained out
Jun 14, 2013 | Indesit W 123 Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
Hi my F &P dishdrawer unit (DD603) won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Fisher and Paykel Dishwashers
Hi, my Hotpoint Aquarius + WF630 screen has what looks like something E5 something on the screen and goes from prewash through to spin within a few moments and no water enters. i have made sure the drain...
If you have cleaned the drain filter AND checked the operation of the drain motor, for Hotpoint (and the manufacturer Indesit) E5 states ' pressure switch jammed on full or pump blocked- check switch and module'. Sometimes there can be bad connections between plugs/cables/module (PCB). If you haven't done already please make sure that the pump does actually work by removing the filter, seeing the pump motor and putting the machine on spin. You should see it rotate! Otherwise it looks like a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
My INDESIT W43T washing machine problem is cannot start,water no come in and i check the door also no lock,i try to another stage,only pump water out system function.another stage no function.what should i...
I have index w43t. it makes some abnormal noise from drain pump and water is not drained. I opened the drain filter and found the noise came from the drain motor. How can i solve this problem?
Aug 02, 2010 | Indesit Washing Machines
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
