Question about Husqvarna 295cc Back Pack Blower HVH 130BT
My gas tank is leaking through the gasket at the top of the tank, in my 130BT. Do you have a solution or part?
My avalanche is leeking gas from the top of tank. what causes this
Probably either a leak in the gas lines or connectors at the top of the tank, or gas leaking past the pump/sending unit gasket there.
Feb 03, 2018 | Cars & Trucks
When filling up the gas tank of my 1998 Pontiac Grand Prix SE, it releabsed a few cups of gasoline from somewhere at the bottom of the car. I'm not sure why??? It hasn't leaked since.
Both the fuel pump and gas gage sending units are located inside the tank. They are accessed by a plate and gasket on top of the fuel tank.
If the gasket leaks or the hoses leading to the vent leak, your condition would happen. Unfortunately to confirm the tank would have to be dropped(removed) which requires all the fuel to be removed first. Not a pleasant nor easy task.
May 13, 2014 | 1998 Pontiac Grand Prix
Gas tank leak
Remove the tank & check it out
Tank leaks,Fuel Pump Gasket on top
of tank leaks,fuel lines leak or are rusted out.
Jul 08, 2013 | 1997 Geo Prizm
GAS RUNS DOWN FUEL LINES FROM TOP OF GAS TANK
sounds like sending unit gasket is leaking. drop the gas tank...sorry
Aug 20, 2012 | 1995 Buick LeSabre
I have a gas leak and we think it may be the gasket for the fuel pump...can you help me locate it?
A 99 is most likely fuel injected, so the fuel pump is inside the gas tank. The gasket for this is a large O-ring in the top center of the tank and is unlikely to leak. Thus your leak is most likely in the line, put it up on a lift at a muffler or oil change place and look underneath for the wet spot which stinks of gas, that will lead you to the leaking spot. Gas tanks themselves can leak due to corrosion, this can be where road debris collects on top, and if you have a skid plate under the tank corrosion can build up between the plate and the tank eventually eating a hole in the tank.
Good Luck
Jun 15, 2011 | 1999 Chevrolet Blazer
My 130bt blower stops reving after several minuets. Will start but not rev after running fine for 5-7 minuets?
Hi and welcome to FixYa. I am Kelly. The next time it does this... loosen the gas cap a lot momentarily for about 10 seconds then tghten it and attempt a restart. If if starts right away again the gas cap is bad. It is supposed to breathe via a rubber seal in the cap. There are 5 parts in the cap. If it can not breathe the gas tank goes into a vacuum as fuel drains and you will experience fuel starvation.
Also check inside the fuel tank for debris.
See this link http://www.jackssmallengines.com/help.cfm#Home
Click on
Husqvarna Power Equipment
Blowers
130BT (I used the 2001 - 2007) There is also a 2008-2010 choice
and then click on Fuel tank a.s.s.y
I suspect the problem is either going to the the fuel cap or the fuel filter.
Thanks for choosing FixYa,
Kelly
Nov 10, 2010 | Husqvarna 295cc Back Pack Blower HVH 130BT
I have a gas leak on my 2005 dodge caravan. it's coming from the top of the gas tank at the back, passengers side . i think thats where the fuel pump is ? could it just be a gasket leak?
check the gasket. and return fuel line. or the filter maybe clogged. or u may have a puncture in the tank itselfor something is causing pressure to build up
Sep 12, 2010 | Dodge Caravan Cars & Trucks
Front gas tank leaked when I filled the tank
the top of the tank has an opening where the gas guage sending unit is installed. The gasket can give out and it can leak when the tank is completely full, but won't necessarily show signs of leakage when the tank is partially full.
Requires dropping the tank and changing the gasket... hope this helps.
Apr 20, 2009 | 1997 Ford F250 SuperCab
Husqvarna 295cc Back Pack Blower HVH 130BT Logo
129 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
