Question about Car Audio & Video
Sound storm laboratories f 2800 1600 watt amp
Do you know what size fuses this amp uses
    Problem Solver:
  • 13 Answers
It uses 25amp fuses. 2 of them.
Posted on Jun 15, 2008
What size fuse do i use in my amp
I would highly replacing it with an identical one.
What is the question? More information is needed before somebody can help you.
May 12, 2014 | Soundstream RUB1.700 700 watt 1 channel...
No power up on ssl f2.200 car amplifier
Yes it does. You should be able to use the blue/white wire to turn it on if you are using an aftermarket radio.
Apr 09, 2012 | Sound Storm Laboratories F1200 Car Amp
Need to know what order to hook up red,yellow,and black wire which to positive which to neg and what size inline fuse is needed for my mcd 5080
Red- power Yellow-Memory Black-Ground
Unless the yellow wire has a fuse built into it then....
Yellow- Power Red-Acc/Ign Black- Ground
If the fuse you are asking about is on the radio t s usually a 10 or 15 amp fuse but if you mean for the power wire for a amp then it depends on the power amount of the amp....look on the amp and find the sum of the fuses on the amp and use a inline fuse that is the next fuse size sum...
Ex. 2 40 watt fuses on the amp then 40+40=80 watts so you would want to get a 100 watt fuse. Also remember you can never go to big for your inline fuse with a amp
Aug 22, 2011 | Jensen Car Audio & Video
Need to know what size fuse how many amps and volts for this device.
Rule of thumb for 12vdc to 120vac inverters is 1 amp of fuse for every 10 watts of power. So, this one would use a 7 amp fuse.
Jul 06, 2011 | Inverter Vector Power - 70 Watt, Model...
I have a audition 150 watts x 2ch bridgeable high power amp serial # 00400274 need size of inline fuse. does not show size of fuse on diagram
hi.
if it is 150 watts TOTAL power then you should use a 15 amp fuse.
(150w / 12v = 12.5amps, 15amp fuse should provide the correct protection.)
if the system is 150 watts PER CHANNEL. then it will be 300 watts total and a 30 amp fuse should be used.
(300w / 12v = 25 amps. 30amp fuse should be used.)
30 amp is normally the highest fuse recommended for an car audio system, so i would not use higher than this without taking the unit to a qualified auto electrician, to get the system checked for safety. if you have any further questions please feel free to ask.
Jun 07, 2011 | Car Audio & Video
Watt size fuse do i use to connect a 350 watt stereo/bridgable amp using a 4 gauge power cord
You use the same amp fuse as on your amp, nothing larger. The fuse just keeps the wire from overheating/shorting and causing a fire.. IF you amp has a 30 amp fuse then you use a 30amp fuse off the battery
Sep 10, 2009 | Kenwood KAC-629S Car Audio Amplifier
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Amplifier
the best thing to do would be look in the manual, it may say what ones you need, or find out the sizing and take it to a local halfords etc, they will be able to tell if you take the amp, and it wont cost much at all.
cheers, adam
Nov 03, 2007 | Car Audio & Video
Car Audio & Video Logo
254 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
